I have a curious question for you all.
For those of you who run more than one amp on subs (I run 4-6) What way do you use to provide signal to all 4-6 in the case of having only 1 single output for subs on the dsp? My amps do NOT provide loop through jacks. DSP out is XLR and amps are XLR in.
Cheapest (poor man) solution? Industry standard solution? Good enough solution?
You could make a cable that takes the output of the DSP to the first amp-and then add a second cable to that MXLR and to to another MXLR and then to another and so forth.
As far as how many amps you can drive-"IT DEPENDS" on the output impedance of the DSP and the input impedance of the amps.
You will be fine as long as the load impedance is around 10 times larger than the output impedance of the DSP.
So if the output impedance is 150 ohms, then 10 times that would be 1500 ohms.
With a input impedance of say 10Kohm per amp, then you could hook up 6 amps with no problem.
You can hook up more than that, but the output level from the DSP would start to drop with more amps.
With a higher input impedance you can drive more amps.
Or you can use an active signal distro unit that takes a single input and then drives any number of outputs 4-16 being typical.
That can add noise-but is a solution.
