So I had set up this amp earlier in the day, slapped it on it’s ass and went off to do other things.
The setup:
In club Rebel, we have a four stack of front loaded dual 18 boxes, two boxes per channel of a PL6.0II. It works well for live bands, fills the entire space evenly with bass. We had a big name DJ last week and the bass wasn’t body pounding like these guys like. In came the BASSMAXX Trips, two of them. I figured the 6.0 wasn’t enough so I dragged in my 9.0. All worked well for the event.
Here we are today. I simply swapped the cables from the 9.0 to the 380. The 380 was placed directly on top of the 9.0 with a bar rag to prevent scratching it (I don’t own it...) I did have the thought that the cloth might lead to some heating but that would have to wait and see. The input sensitivity switches easily allowed matching it to the DSP with little tweaking.
I was at another club much of the night. The Rebel tech said all was great and the amp was running real cool. I was skeptical. I was able to stop by around 2AM. It was hard trance/electronica with solid low frequency. I was downstairs in the crowd first, the place was packed. This particular track had sustained low frequency, had to start at 35Hz, then 45, then 60, etc. Each tone was held for a good thirty seconds, the bass output was huge. I was thinking that the amp must be at it’s end and the DSP in limiting and are these woofers going to survive? The bass level was pretty eyeball shaking. Those of you who were at The Sub Shootout heard these subs at this level. I shoved my way upstairs to see the amp only hitting the second lights, one more light to go before the red lights. There was good headroom left. Also surprising me was the lack of heat from the amp. The poor lighting tech was stationed top side and thanked me for not using the other amp as it ran way hotter. He was talking about the 9.0.
Overall, I’m very impressed with the amp. It works as advertised. No issues at all. I can't say it bested the 9.0 but it was pretty good. There was no lack of bass level. One can only tell if you A/B it with the 9.0. It's certainly lighter, cooler and cost less than the 9.0 did when new. One more night at Rebel is in line for this amp. Huge power. 24 pounds. HUH. I don’t know how this amp will compare to the 9.0 with a 2 Ohm load but it’s starting to look good.
