Sorry Al, the microphones were NOT SM57s.
Initially they were Sennheiser MD201 dynamic omnis, later replaced by small diaphram B&K instrumentation condensers.
For the differential microphone thing to work the two microphones had to be as closely matched as possible and the singer needed to stay right on top of the "working" microphone element.
The better matched the microphones were the more of the "difference" was the vocal.
It was found after a while that the condensation from the singer's breath on the the top micrphone threw the mikes out of calibration mid show. So, in typical, "over the top Grateful Dead crew style :-)" a way was found to heat the diaphram of the top mike to keep the condensation from building up.
The curved center cluster was the vocal array. Woofers were JBL 2202 12 inch, cone mids were JBL 2105 5 inch, and the tweeters were EV T350s.
The smaller curved array over the keyboard position was the mixed keyboard system.
Every other instrument on stage came out of it's own dedicated "line array" of speakers. the Guitars, Bass, and kick drum came out of really TALL columns of 12 or 15 inch speakers.
Power amps were mostly McIntosh MC3500s, really HEAVY 350 watt tube amps.
If you poke around the Web, some really obsessive Deadhead probably has posted more about the system than you ever wanted to know.
It sounded pretty "hi fi" in medium large venues. It took more than a full work day to set up. It cost a lot of money to truck around during a fuel shortage.
It was replaced by a system based around Meyer MSL3s which went up faster, took up less truck space, and sounded better more of the time.
Cheers,
Lee "audio archaeologist" Brenkman
