Author Topic: Dumb 70v question  (Read 1008 times)
Re: Dumb 70v question
« Reply #10 on: May 24, 2024, 10:05:26 AM »
I have ran into a few people who thought....maybe still think that you should be able to always measure 70 volts on a 70 volt system!!
Only on the test bench ...  AKA constant voltage systems but they aren't constant voltage either....
Don't over think it 70/100v are nominal rated power voltage outputs.
« Reply #11 on: May 25, 2024, 03:16:26 AM »
The way I read it that’s what Bryan Jojadie was saying.
« Reply #12 on: May 29, 2024, 01:29:34 PM »
You won't always reach the 70 volts until you reach a certain level.
What a 70V or 100V etc system simply means is that when there is 70V on the line, the power of the rated tap (or close enough) will be what is delivered to the loudspeaker.
At lower drive levels, the wattage will also be lower.  So at 35V the level would be 6dB lower.
« Reply #13 on: May 29, 2024, 01:35:46 PM »
Think of it like this.
All the taps basically do is change the impedance of the loudspeaker.  So a lower wattage tap results in a higher impedance unit, which means less sound than others with higher wattage (lower impedance) taps.
A 1 watt tap is (for simple math) 5000 ohms, 10 watts is 500 ohms, 100 watts is 50 ohms.  Or any combination of taps from any number of loudspeakers.
A 600 watt amp into 8 ohms is a 70V source by itself.
Using the taps to adjust level is the main reason for the various taps.
Let's say you have an airport with all sorts of different ceiling heights.  You change the taps accordingly (all on the the same speaker line) for the difference in height (inverse square law) to the listeners ears.
You could use a volume control, BUT IT MUST be a 70V type, NOT an L pad.  All a 70V volume control does is to adjust the taps via the switch position.  You cannot get it inbetween positions.
Page created in 0.03 seconds with 23 queries.
