Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > LAB: The Classic Live Audio Board
Proper workflow for Zoom meetings with multiple cameras
Justice C. Bigler:
--- Quote from: Mike Caldwell on July 13, 2021, 12:00:23 AM ---The Mini Pro can stream directly to streaming host URL via it's built in encoder and using the ethernet connection.
You do need to set it up using the control software connecting to the computer running the software with the USB connection.
The multi view monitor option displays all the vital information.
BMD figured out how to cram a lot of features in a small box, make it work all for a crazy price.
--- End quote ---
The ATEM Mini Pro only streams via Facebook, Youtube, and Twitch, Twitter. It won't stream to Zoom. For Zoom you have to use the USB connection as a webcam on a computer that is running Zoom. I think this is what threw me the most, trying to figure out the routing out of the ATEM and into Zoom. It's the two-way communication through Zoom that I think causes the most difficulties. Trying to figure out how to project a large screen Zoom window so that the attendees in the large room can see and hear it, while also controlling which camera the switcher sends to the Zoom session, seemed to be the difficult part of the whole operation for me.
You have the ATEM Mini Pro connected to a computer by USB to fake the webcam connection into Zoom. Then you have an output from...the Mini Pro? Or the Computer for the Zoom session on the large screen? :-\
So really, you have to run the Atem control software on the same computer that you run Zoom on...I think? Regardless of where the PowerPoint is coming from.
And then to complicate things even more, I had an external mixer feeding the Atem Mini Pro audio inputs so that we could have more than just two mics going into the Atem Mini Pro/Zoom.
I guess, I'm trying to figure out where the best place is to feed a large screen/projector for the main room and how to do so? As a second display from the laptop? Or as an output from the ATEM Mini Pro? Or from a Second laptop that isn't connected to anything else except the Zoom session (which means we need two Zoom accounts then)?
Nils Erickson:
I think it is easiest to have the Zoom Client on one laptop. A second laptop can control the ATEM software; I think this is easiest since you don't have to constantly toggle between apps. I have the USB out of the ATEM feed the webcam input on the Zoom meeting. Then I use the HDMI out of the Zoom laptop to feed the large screen. I use the ATEM HDMI out to feed a multi view screen.
I think Tim's idea is good to have another machine run the PowerPoint. Or, you can run it on the Zoom laptop if you are the host of the Zoom meeting. Then you can be in charge of screen sharing so that it happens correctly. But, again, it is a lot of toggling between apps to make all of that work on one machine smoothly.
Sounds like you are on the right track!
Cheers,
Nils
Helge A Bentsen:
Nearly OT, but if you're doing these meetings with a small number of people in the room, drop the PA and use small speakers.
Cleans up the audio for all involved and generally makes for a better meeting.
I've done dozens of these meetings the last year using small speakers distributed around the room.
Also, decide what's the most important audio destination and run that through your console master bus for more accurate meters and ease of operation. If the meeting audio is most important, it goes there and other destinations off auxes/matrixes. If the room audio is most important, I run the room off L/R from a set of matrixes and the meeting from whatever easiest.
(Not saying you should ignore those other mixes, but set up your console to match what people prioritize).
Mike Caldwell:
--- Quote from: Justice C. Bigler on July 13, 2021, 02:55:51 AM ---The ATEM Mini Pro only streams via Facebook, Youtube, and Twitch, Twitter. It won't stream to Zoom. For Zoom you have to use the USB connection as a webcam on a computer that is running Zoom.
--- End quote ---
I forgot that Zoom wants a "webcam" connection.
Yes and no on the control software....unless your using some of the enhanced ATEM functions that are only available with the control software opened once you set it up the software can be closed and kind of forgotten about.
You can also control the ATEM with an ethernet connection to another computer if you do need the control software during the presentation.
Scott Helmke:
Letting people run their own Zoom session like a casual meeting is like handing somebody a wireless lav and expecting them to clip it on correctly and then remember to turn the pack on. At some level of professionalism you have to turn it into a real production, which is a new thing for most of us since it's a lot of video.
There's a Chicago-based company that does mostly high-end online meetings, and they go to the extreme of having a separate Zoom (or similar) session for each major participant. Think of a rack (or a room) full of computers, each one doing the local end of a one-person meeting. The video and audio then goes to a big switching and mixing matrix (they use a PM7 for the audio portion) and it's run like a big live sales meeting.
That's the extreme, of course. But it's good to think in those terms, like having separate computers for playback, etc.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
