Author Topic: Connecting two Riedel key panels together  (Read 1709 times)
Tommy Bridwell
« on: October 16, 2019, 03:51:56 PM »
Hey guys,
I have an interesting scenario here. I have 2x Riedel 1128 key panels that I want to be able to link together so that a person can have 40+ individual keys all viewed at the same time rather than viewing them on a shift page. Do you know if there is a way to link two key panels together to act as an extension of the first one so that the someone can view all of the keys at once and talk on one mic input? I would like the second panel to basically be an extension of the first panel with channels 29-56 essentially.
Any help is appreciated.
Tommy
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #1 on: October 16, 2019, 04:52:51 PM »
Hey guys,
admin
Pete Erskine
    • Best Audio
Re: Connecting two Riedel key panels together
« Reply #2 on: October 17, 2019, 09:57:13 AM »
-- this method only really works with P-P so
        put all of your P-P on the second panel and party lines on the main
-- setup both panels (Main and second) with similar names like bob. and bob,
        (minor difference)
-- create a group which has both panels in it as members and name this group BOB
-- this is the key you put on everyone else's panel
-- when they call, the audio will be sent to both panels
            (keep the master down on the second panel)
-- when you reply to them using the reply key on your main panel it will go to them
-- It also won’t let you call them using the second panel button,
            to do that do the following
-- enter all of your p-p on the shift page of your first panel
       (Open both main shift and second and drag keys to shift)
-- enter an additional remote key command on each button on the second panel
       to remote push the corresponding shift button on the main panel.
NOW it will seem to be linked - after only 2 hours of programming
better…If you are using GN Mics just stack the panels and have the mics together.
Remember to put both panels in the same room code so you don’t get feedback
« Last Edit: October 18, 2019, 12:23:12 AM by Pete Erskine »
Pete Erskine
917-750-1134
www.bestaudio.com
[email protected]
Tommy Bridwell
« Reply #3 on: October 23, 2019, 07:32:43 PM »
        (minor difference)
Thanks for the detailed description. Although its is not exactly the setup I was imagining (I'd rather use one microphone) I can see how this would function.
Do you think a better way of achieving this is to create all of the channels on the master keypanel (pages 1 and 2) and then use a second keypanel as a remote trigger for all of the channels on the shift page of the master keypanel? I believe then you could still use the mic on the master panel to talk from the slave panel since it is activating the shift page of the master panel. Or is that even possible? Forgive me is this doesn't make any sense.
Thanks again for the help.
Tommy
Pete Erskine
    • Best Audio
« Reply #4 on: October 23, 2019, 09:40:07 PM »
Tommy
First: The first method uses only 1 mic...
Second: Your suggestion is exactly what I described except it only works with P-P.
Remote keys alone would work BUT the keys would not display the led buttons.
Pete Erskine
917-750-1134
www.bestaudio.com
[email protected]
Page created in 0.026 seconds with 24 queries.
