I am somewhat stumped on this one. I put together a patch panel for my racks with a powercon in and out connector. The powercon input has a tail with a female edison and I plug my tripplite strip into it. The powercon output has a tail with a male edison and plugs into the strip. Whenever I plug the unit into a GFI powersource it always trips the GFI. I have triple checked the wiring and used a receptablet tester to check the connection and it is showing everything as correct. Any suggestions on what the problem might be?
