I'm needing some help or explaining in regard to setting limiters particularly on my subs. I'm not new to audio but not as experienced as I'd like to be when dialing in a system for maximum performance.
Here's the rig:
4 x Peavey SP2G mains - Power handling (300/600/1200)
6 x Peavey SP118's subs - Power handling (350/700/1400)
4 x QSC PLX 3402's - Power 700 @ 8/ 1100 @ 4
2 x QSC CX502's
1 x Peavey VSX26 DSP
Here is the manual to my subs
http://assets.peavey.com/literature/manuals/80304323.pdf however I have 2 that are the 4 ohm version and 4 that are 8 ohms. Identical basket model with exception of the resistance.
I've not setup my system for 3 way operation yet until I get a good grasp on setting these limiters as my 502's will be for the horns and have more power than my horns need.
Setup is: (until I get another 3402 for the subs)
3402 - SP2 / SP2
3402 - SP2 / SP2
3402 - SP118(8ohm) SP118(8ohm) / SP118(8ohm) SP118(8ohm)
3402 - SP118(4ohm) / SP118(4ohm)
I started with the SP2/118 preset for the VSX26 from Peavey's website.
The Peavey preset says my sub settings should be:
X-OverLow corner freq - 45Hz Slope = Bessel 24
Upper corner - 110Hz Slope = LR 24
Gain +2dB
Eq80Hz +4.5dB .700 bandwidth
120Hz +3.5dB .600 bandwidth
The mains I'm not very concerned with as I have them at -6dB on the x-over to keep a good balance and overall they sound pretty good after some very creative eq'ing. However, once I'm sure I'm doing everything correct I will absolutely re-set the limiters there as well.
I don't have a SMAART rig so all settings have been by ear and or using factory numbers and math. Overall I think the system sounds pretty good however the issue I'm having is the lows quickly run out of steam and start to bottom out before they're thumping. I do understands this is not a top tier system and it's nearly 20 years old and those subs don't go super low or loud but I do believe they should hit a little harder.
My first question is: my spec sheet says the -3dB point is 48Hz and the -10dB point is 38Hz but the peavey preset is saying it should be 45Hz. I'm fairly certain these system settings were measured at Peavey using a newer version of the SP118 so that probably needs to be raised to 45Hz on my DSP I believe.
My next question/issue is the limiter settings for my subs...
Doing the math for setting the RMS limiter of the VSX. (only has RMS limiting) (the 3402's are 40x gain)
20log (((SQRT(Watts x Resistance))/Gain)/.775)
20log (((SQRT(350 x
)/40/).775)
20log((SQRT(2800)/40/).775)
20log((52.915)/40)/.775)
20log((1.323)/.775)
20log(1.71)
4.65
So according to the math, assuming it's correct my limiter should be set to start engaging at 4.65dB input. Ok that's fine except by the time they engage I'm bottoming out the driver and the clip light on the 3402 is lighting. That's putting music thru a board and the main outs just tickling the 0dB light.
I've found that to keep the subs from distorting and bottoming out my limiter needs to be set at -4dB.
So here are the questions I have regarding the setting of the limiters.
1. Is the low corner frequency difference of 3Hz causing all or part of the issue?
2. When RMS limiters are set (properly) should you see the clip light on the amps if you're staying under 0dB on the board and the channel isn't above 0dB as well?
3. Am I misinterpreting the math and the 4.65 number means a reduction in gain rather than the actual dB setting? My VSX says it has +24dBu outputs so I'm taking the math I've done to represent the actual output level rather than a reduction of 4.65dB, is that correct thinking?
4. Is my math correct?
I have a small version of my rig setup in the garage sp2 over sp118 per side and even standing within 10 feet of the system it gets loud but still not a lot of punch. I know they used to hit a lot harder, at least I believe I remember them hitting harder. The baskets are pretty new and have not been run hard so I don't think they're the issue, maybe but I don't think so.
The time I am remembering them hitting herder they used to be run off of Peavey GPS3500's, can switching to the PLX3402's actually make a difference? I know the switching amps are sometimes said to be inferior on subs because they don't "store" power for those big hits but is that true?
Anyway, any and all help will be appreciated. I really want to get better at the math and science of a sound system rather than just being able to mix well.
Thanks. If there's anything I missed just ask and I'll answer as best I can.
