Author Topic: Midas pro 1 vs pro 2c  (Read 22718 times)
Brian Wynn
Re: Midas pro 1 vs pro 2c
« Reply #10 on: November 13, 2012, 03:18:37 PM »
Midas Pro doesn't have parametric on outputs? Really?
It does but you have to pick between parametric or graphic.  They have a work around which doesn't allow you to pull the graphic up on the faders.  Or the other work around forces you to  use a Matrix for your outputs to get a limited parametric eq.
Peter Morris
« Reply #11 on: November 13, 2012, 04:35:59 PM »
More Local I/O
Multitrack recording out of the box
USB recording
USB playback
Use of both parametric eq and graphic on your outputs
1/4" aux inputs
1/4" aux outputs
Single cat5 snake
Cost
Multiple ways to get to your aux sends
I'm not a Behringer fan but its hard to beat this desk for the money.
Pro 9
•   288 inputs x 294 outputs (max capacity) point-to-point routing anywhere within the Network
•   80 primary inputs
•   8 return inputs
•   Up to 104 simultaneous mix channels
•   16 Group/Aux & 16 Matrix - 32 Mixes in “monitor” mode
•   35 mix busses
•   10 VCAs
•   6 POPulation Groups
•   Up to 16 multi-channel FX engines
•   Up to 36 KT Graphic EQ’s - with optional DN9331 Rapide control
•   Configurable “Area B”
Pro 2
•   156 inputs x 166 outputs (max capacity) point-to-point routing anywhere within the Network
•   56 mic/line inputs with MIDAS mic preamps
•   64 simultaneous input processing channels
•   32 analogue outputs (including 2 stereo local monitor outputs)
•   3 AES3 outputs
•   2 AES3 inputs
•   27 sample-synchronous, phase-coherent mix buses
•   6 multi-channel FX engines
•   Up to 28 KLARK TEKNIK DN370 31-band Graphic EQs
•   8 VCA (Variable Control Association) groups
•   6 POPulation groups
•   192 MCA (Mix Control Association) groups
•   96kHz 40-bit floating-point processing throughout
X 32
•   32 inputs
•   16 mix busses
•   8 VCAs
•   Up to 16 Graphic EQs
•   48kHz 40-bit floating-point processing
Samuel Rees
  • Washington, D.C.
« Reply #12 on: November 13, 2012, 06:13:19 PM »
Weird. I can't think of any other desks I've used that are like this, off the top of my head.
Dave Barnett
« Reply #13 on: November 13, 2012, 10:56:20 PM »
While the m7 is not my favorite desk it is fairly widely accepted. If your getting a good deal great. My last advice would be to look at your workload over the last year and see if this combination would have fit the bill most of the time. Like I said if YOU. Are the operator it doesn't matter what it is but if you are needing to meet even regional riders a LS9 might even be a better choice from a business perspective.
When would an LS9 ever be preferred over an M7 with regard to rider acceptance???
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #14 on: November 13, 2012, 11:18:59 PM »
Never.  But it is cheaper.  Which might still make it a better business decision....
brian maddox
[email protected]
Savannah, GA
« Reply #15 on: November 14, 2012, 12:04:51 AM »
Yeah, but the UI sucks.  I can accept the "average Yamaha" sonics but I hate navigating it.  An 01V96 is faster and easier to get around on and it shares many of the same UI concepts.  Not sure exactly what it is that throws me off but I'd rather use a DM1000 or an expanded 01V96.
brian maddox
« Reply #16 on: November 14, 2012, 09:08:31 AM »
i actually had this same problem.  Their Centralogic is a pretty major departure from previous UIs.  i did get the hang of it fairly quickly, but you're right.  it was off putting at first.  And i, like you, am VERY comfortable on an 01v96.
brian maddox
[email protected]
Savannah, GA
Thomas Lamb
« Reply #17 on: November 14, 2012, 12:00:47 PM »
What I was trying to imply (going back to my original post) was that in some situations a ls9 may be preferred over a pro1. Simply because it would be much more comfortable to operate for many people.
bigTlamb
"If you suck on a functional analog desk, you'll really suck on a complex digital desk...." Dick Rees
Β« Reply #17 on: November 14, 2012, 12:00:47 PM Β»
