drewgandy wrote on Wed, 03 December 2008 15:17 |
Quote: | * Measurement Made Using 2.83 Volt, 4th Order, Band-limited Pink Noise from 38 - 80 Hz * One Cabinet Measured 106 dB and Two Cabinets In Parallel at four Ohms were measured to be 109 dB
This little bit of info doesn't seem to add up. With 2 cabs in parallel I would expect a roughly 6 db rise in sensitivity. Otherwise, yes they look awesome. Little jet engines. I wonder if you can use them to warm your hands on that outdoor gig. (oh, its in florida isn't it?)
Unless the input voltage was dropped to 2 volts for a 1 watt input.
Also the use of pink noise is questionable. Is the reading of the "average" of the pink noise signal or the top of the crest-which typically is 6 db higher and up to 12dB.
Or maybe better put, is the 2.83V the average of the pink noise signal or the peak.
Ther are all sorts of games that can be played with numbers and measurements. Unless you know the rules (parameters of the test-test gear-measurement conditions etc), it is hard to tell exactly what you are dealing with sometimes.
