Author Topic: Light Clamps and Safety Cables  (Read 4461 times)
Aaron McQueen
« on: September 24, 2007, 09:51:15 AM »
Which ones do to you like (for standard PAR56/64)?  Where do you buy them?  When do you use the safety cables?
E. Lee Dickinson
    • http://www.leedickinson.com
Re: Light Clamps and Safety Cables
« Reply #1 on: September 24, 2007, 04:21:55 PM »
I like the spring steel hook clamps that are more common in europe, as opposed to the popular forged clamp sold here. I do NOT like the 'super hooks' or whatever they're called that have no pan adjustment!
As for safety cables, ALWAYS, in this order:
Hang light, keep hand on clamp, finger tighten bolt, then safety cable, then wrench tight. Opposite when striking.. wrench loose, remove cable, then all the work is with your hands.
The point being that the instrument is safed any time you're fumbling with your wrench, and while you're torquing the C-clamp down, as that is the most likely time for it to fail.
E. Lee Dickinson
Advanced Visual Production Inc.
sound - lighting - video - design
www.avpric.com
Tom Manchester
    • http://www.electrosoundsystems.com
« Reply #2 on: September 24, 2007, 04:59:30 PM »
I like the Mini and Mega clamps from this place: http://www.thelightsource.com/
They should be available at your local guitar center for ~$7 each, or online for less. I use safety cables on ALL of my fixtures regardless of size.
-Tom
Electro Sound Systems
E. Lee Dickinson
« Reply #3 on: September 24, 2007, 06:47:44 PM »
Mega clamp.. that'd be the one with no Pan adjustement.. unless you loosen the bolt that keeps it from falling on audience heads. Don't like those much.
E. Lee Dickinson
www.avpric.com
Phil LaDue
« Reply #4 on: September 24, 2007, 06:53:59 PM »
I'll a big, old, heavy, Altman clamp any day of the week.
Nothing feels as sturdy.
If it doesn't have a spot for a safety cable, make one!
Anything 4ft or more above the ground and not in a frame should have cable, period.
StJohn Gill II
« Reply #5 on: September 24, 2007, 09:25:20 PM »
Every fixture I sell comes with a hook clamp and a safety chain - it's automatically built into the cost. Evety fixture hung *should* have a safety chain - but especially those over the audience.
For heavier fixtures (really only large intelligent lights) it is wise to move up to a more solid clamp - even though they are hung with 2 clamps, i rather something more solid - like the ones that look like scaff clamps.
Craig Leerman
Mega Clamp
« Reply #6 on: September 24, 2007, 09:40:14 PM »
There is no danger when adjusting the pan on a Mega Swivel Clamp. under normal circumstances, with the fixture hanging below the clamp, you can set the tension on the bolt so the fixture will swivel left and right, and the spring washer will keep it in position. When used in other positions (like hanging the fixture sideways from a pipe) you can simply loosen the bolt a bit, position the fixture, and re-tighten the bolt. Because the bolt is over an inch long, there is no accidental chance of it coming out.
I've been using these for a while now on Pars, Cycs and Bars.
Of course, if you are still worried, they make a swivel Mega with a pan bolt.
index.php/fa/11454/0/
http://www.thelightsource.com/products/16/view
E. Lee Dickinson
Re: Mega Clamp
« Reply #7 on: September 24, 2007, 10:51:11 PM »
That's cool - I had never seen the one with the jesus bolt.
For my complaining about pan ability, my preferred clamp, and the clamp on every single fixture I own, is a standard 2" truss clamp. THOSE are a PITA to lock off into position.
E. Lee Dickinson
www.avpric.com
Eric Hassler
« Reply #8 on: September 25, 2007, 12:52:29 PM »
Tom Manchester wrote on Mon, 24 September 2007 15:59
Be sure to look carefully at the clamps from Guitar Center.  The screw doesn't always line-up with the point in the "C."  I had to go through over ten of them to find four good ones the last time I was there.
Daniel Cash
« Reply #9 on: September 25, 2007, 01:28:39 PM »
Eric Hassler wrote on Tue, 25 September 2007 11:52
I think my church has a bunch clamps with that defect.  No wonder they never clamp on the truss quite right.
Page created in 0.041 seconds with 20 queries.
