Author Topic: TC M350  (Read 17122 times)
Andy Peters
    • http://www.latke.net/
TC M350
« on: May 09, 2007, 02:04:08 am »
The friendly guy in the brown truck dropped off some packages last Friday, one of which was a TC M350, which is positioned by TC as their lowest-end digital effects device (list price $249).   It's a "dual engine" device, with one engine dedicated to non-reverb effects (like delay, flanging, chorus, phaser, tremolo and compression) and the second dedicated to reverb.   It has two inputs, two outputs (all balanced, BTW), as well as S/PDIF digital I/O. It has a MIDI port for control, set-up dump and firmware update.  A standard IEC jack attaches to the locale-specific power cord; the switch-mode power supply accepts any mains line voltage.
Natch, the first thing I do with any piece of gear is to open it up and poke around.  Inside are two PCAs.  One is a single-sided job that's the power supply (it looks like TC buys somebody's supply) providing +15V and -15V for the op-amps, +5V for the converters, and +3.3V for the digital stuff.  The other PCA holds everything else.  A Freescale (formerly Motorola) 56362-120 (about $8 in 1K qty) is the DSP, which
is connected to an SRAM and a flash EPROM.  Presumably, it's clocked at 120 MHz (it has an internal oscillator and I didn't check to see if the system clock is brought out to a port pin) so the DSP does 120 MIPs, which is obviously sufficient.  Like all Moto 56K parts, it's a fixed-point 24-bit processor, with a 24 x 24 MAC and 56-bit accumulators.  An Atmel ATMega 8-bitter handles MIDI and user interface.  The DAC and the ADC are AKM parts.  Opamps are 5532s.  Ferrites are used at all I/O ports for EMI suppression.  I/O is balanced although it appears that the outputs use the simple build-out to ground for the inverting line (which is fine).
The M350 can be configured, via rear-panel switch, in one of two ways:  One is as two parallel effects engines, with one input for the effects engine and the other for the reverb.  In this mode, both engines have stereo out which are combined to drive the outputs.  A balance control sets the relative level of both engines in the mix.  The other configuration is serial, with the effects engine first, followed by the reverb engine.
I've been pretty vocal about my dislike of the dual-engine with one output configuration.  It has to do with how I mix.  I like to bring my effects into the console on their own inputs.  I like to set up, on the input channel aux send knobs, the proper blend sending to an effect, while trying to keep the effect's input level decently hot (best effect S/N), and then adjusting the level of the effect in the mix on the return fader.  Usually the return fader lives somewhere other than at unity.
Having two effects combined in the box means you have to put the effects return faders at unity (or some other convenient level) and then establish the level of the effects in the mix on the effect input, which is a pain, perhaps less so if your console has faders for the aux send masters.   Of course you're boned if you want to use the box in the parallel mode but also send the delay output to the reverb (since vocal that's fed to both a reverb and delay with the delay kept dry sounds kinda weird to me).  So it's a simple matter to say "this is a single-engine device," especially since each engine's effect select has an "off" position.
This brings up another important topic: User Interface.  And the M350's interface is kinda spartan, similar to competing products in its price range.  There are the expected input-level and blend (wet/dry) knobs, and the effect balance knob.(There's no output level knob, which is fine, as most users set it to maximum.)
Each engine has a 16-position effect-select switch (as noted, one position is "off"). The Delay/Effect engine has two pots for parameter adjustment and the Reverb engine has three such pots.  The 12 o'clock position of each pot is what TC calls the "normal" setting.  One could reasonably ask, "What's normal?"  For example, the Reverb engine has controls for Predelay, Decay Time and "Color."  If you choose the Gold Plate program, what's the decay time?  Seriously.  At my show on Saturday, the opening band had a mixer-person, and he asked for a 2 second reverb.  On many pro-level reverb boxes, the reverb decay setting is simple.  On the M350 (and similar units from Lexicon and others, let's be honest here), there's simply no way to know your decay time.
And this is where the whole dual-engine-summed-into-one-output concept falls on its face: you can't cue up just the reverb to fine-tune it... you also hear the delay engine.  (Similarly, you can't cue up just the delay without hearing reverb.)
The delay engine has an interface quirk related to this "normal" setting.  You actually set the delay using the tap button.  If the delay time knob is in the "normal" position, the delay time you tap is what you get (and you can fine-tune it by turning the delay knob). However, if the delay time knob is not at normal, then the time you tap gets varied by the amount the knob is offset from normal, which is annoying until you realize what it's doing.  Advice: leave the knob at 12 o'clock and tap your delays and be done with it.
More to come ...
"This isn't some upside down inverted Socratic method where you throw out your best guess answers and I correct your work." -- JR
Andy Peters
Re: TC M350
« Reply #1 on: May 09, 2007, 02:25:58 am »
More about the TC M350 ...
TC tells us that the M350 is "Perfect for Computer Recording ... Through the included software, the user can control and edit the M350?s parameters stand-alone and in any AU/VST environment. "
The demo unit didn't include a CD, so I followed the link to "control software" where I was able to download the Vyzor Control Software for OS X.  I installed it, connected the unit to my M-Audio MIDI gizmo, and ran the software.  I was then asked for a serial number for the software (!!), which is NOT the same as the unit's serial number.  How to get a serial number?  Follow the link where you're asked for an e-mail address and your name.
Note to TC: You've just annoyed me.  The Vyzor software has one purpose: to control this particular box.  So why do I need to register it and get a serial number?  It's not like I can use the software to control my LXP-5?  No!  So, please: drop the stupid serial number.
I haven't had a chance to play with the control software yet.  I hope that it offers reasonable control of things like reverb time, kinda like how a Lexicon MRC makes the LXP-1 and LXP-5 units actually usable.
Another potentially interesting use of this box is as a plug-in for a DAW, using the S/PDIF I/O.  The note above mentions "the user can control and edit the M350?s parameters stand-alone and in any AU/VST environment. "  There's a comment about this: "For more information about availability of an Audio Units version of the Control Software, please click here."  So I clicked there, and we're told that "We hope to have the Audio Units version available for download from our webpage in march 2007."  Well, it's the lusty month of May, so I've filed AU support for the device under vaporware.  (Maybe by the time it's real, I'll have figured out how to use Logic 7.)
-a
Bennett Prescott
    • http://www.adraudio.com
But How Does It Sound?
« Reply #2 on: May 09, 2007, 05:30:02 pm »
Hey Andy,
Thanks for really tearing up the box and seeing what makes it tick. How would you say the sound quality of the algorithms stacks up against other FX units in its price range? I've always thought the M300 makes a good drum and instrument FX unit, but the new M350's reverbs sounded even better at AES.
-- Bennett Prescott
Director of North American Sales
ADRaudio d.o.o.
Cell: (518) 488-7190
"Give me 6dB and I shall move the world." -Archimedes
Jeff Babcock
Re: But How Does It Sound?
« Reply #3 on: May 10, 2007, 03:21:17 pm »
Interesting.  The M300 has come in handy on lots of occasions, particularly the tempo-tap delays.  I couldn't agree more with your comments about summing the dual engine to common outputs... it kind of is crippling....  aside from that though it's been a good unit.  Unless the reverbs are A LOT better, for what I use it for, I'll stick with the old 300.
Andy Peters
Re: TC M350
« Reply #4 on: July 14, 2007, 06:42:56 pm »
Sorry for the delay between posts about this thing.  Anyways ...
About the control software, called Vyzor M350, apparently written by a third party.
The product's web page tells us that, "through the included software editor, parameters and preset recalls may be fully automated or real-time controlled."  Ignoring the awful syntax of "may be real-time controlled," I downloaded the software, and installed it on my MacBook Pro.
As I noted before, for whatever stupid reason TC requires you to get a serial number for the software. So I registered for the software, and it asks for my name and my e-mail address.  I expected to get an e-mail with the magic serial number, but no, I just get to a web page with the serial number.  So the deal here: print that web page so you don't lose the number and have to re-register.  Why ask for an e-mail address?
NB that the promised Audio Unit support still has not materialized, although there is VST support if your DAW software can use it.
After getting a serial number, I connected an M-Audio USB Uno MIDI interface to my MacBook Pro, then connected the MIDI tails to the M350.  I ran the software and it asked me which MIDI port to use, so I selected the Uno and it seemed to recognize the M350.  I was able to fetch user presets from the box.  The main window of the program has an image of the M350, which, when clicked, opens up a large photo of the front panel and all of the user interface controls are clickable and changeable.  However, after changing a few controls the software (which was v1.00) crashed.  Restart, re-set MIDI port selection, open up the front panel, play a bit, crash again.
I did about five or six cycles of this, until I got pissed off and checked the TC Electronic web site and sure enough, there's a v1.3 of the control software.  I downloaded it, read the READ ME FIRST.pdf file, which told me that I needed to update the firmware in the M350 to work with the new software. OK, that's fine ... except the disclaimer: "The M350 software upgrade can only be done using a PC running Windows. (emphasis theirs) We have only tested it under Windows XP, but it may also work under other versions of Windows."  On the next page, we're told, "Please note, the software update cannot be made under Mac OS X. (again, emphasis theirs) This is not a deliberate choice on the side of TC Electronic. We know a lot of studios and musicians use the Mac."
In other words, go fuck yourselves, Mac users.  This is an EXCELLENT reason to take the unit out of the rack, put it back into the box, and return it.
More to come ...
Andy Peters
Re: TC M350
« Reply #5 on: July 14, 2007, 06:51:46 pm »
Oh, I figured that I had nothing to lose by at least installing and running the v1.3 software without doing the firmware update, so I did.
And it turns out that what's labeled as v1.3 on the web site still shows up as v1.0 when one does "About Vyzor M350 ..."
Ooops.  Somebody at TC needs to, you know, get that sorted out.
Gotta dig out the ThinkPad and do the FW upgrade.  I suppose I could try it under Parallels, as the new v3.0 has some excellent hardware support (I can talk to a Silicon Labs serial JTAG dongle using a Prolific USB-to-RS232 converter with the SiLabs software running in Parallels).
Poll! Should I do it from the Mac under Parallels, knowing that I could brick the M350?
-a
Michael 'Bink' Knowles
    • http://www.binkster.net/index.shtml
Re: TC M350
« Reply #6 on: July 15, 2007, 12:27:36 am »
Andy Peters wrote on Sat, 14 July 2007 15:51
...Poll! Should I do it from the Mac under Parallels, knowing that I could brick the M350?
I say risk it but then it's not my money. Once you try it, people will know from your experience whether it's possible or not so even if you lobotomize the one on your desk you will have saved others out in the field.
I can't believe TC hasn't tried it themselves.  Confused
-Bink
www.binkster.net
Robert "Void" Caprio
    • http://www.interzonestudios.com
Re: TC M350
« Reply #7 on: May 24, 2008, 10:04:32 am »
Just bought an M350 at the behest of my client and so far I do dig it but would be very interested in getting it to work with my Macbook Pro. Any new updates on this? I would prefer not to brick my unit but at the same time I doubt that would really happen. i have heard all the warnings about stuff like that and it's never happened, at least not yet. Rolling Eyes
FOH/Mon/TM/PM/RF Tech
Interzone Studios
Tour Blog
Tony "T" Tissot
    • http://www.4dbsound.com
Re: TC M350
« Reply #8 on: May 27, 2008, 03:55:19 pm »
I use a couple of M300 (because I'm cheap). They are roughly equivalent in sound to the 350.
The dual effect thing is annoying enough where I gave up using it. I use one unit for delay and the other for verbs.
MNGS
ProSoundWeb - Home of 50,000 audio professionals - and two or three curmudgeonly SOBs.
Tim Padrick
Re: TC M350
« Reply #9 on: May 28, 2008, 11:23:43 pm »
Tony "T" Tissot wrote on Tue, 27 May 2008 14:55
What's annoying, other than that the outputs are summed?  I find this easy enough to live with.
Page created in 0.041 seconds with 20 queries.
