Author Topic: Cable Grounds  (Read 671 times)
Mark Strong
    • http://www.myspace.com/Doctormetal
Cable Grounds
« on: April 02, 2007, 02:58:43 pm »
I recently made a small snake(xlr-trs) for a Roland(VS-1680) mixer (6 trs Inputs). After putting it together, and testing it out, I noticed a hum in the signal when either the microphone or connector plugged into the mixer was not touched. And I could made it go away by either touching the TRS connector, or the microphone with my hand. The mixer had grounded power.
Its wired pin1-Sleave, pin2-Tip, pin3-Ring (xlr-trs).
I have heard not to connect anything to the shell ground on the xlr, and have heard to connect the shell ground with pin 1.
When I looked on my big snake, I noticed they connected pin1 to the shell ground. So do I connect anything to the shell ground on the xlr, and do I change anything on the trs end?
Also, on all my xlr cables, I did not connect anything to the shell ground, but have had no problems. Is this correct also?
Greg Cameron
    • http://www.cameronproaudio.com
Re: Cable Grounds
« Reply #1 on: April 02, 2007, 09:02:37 pm »
In general, the shell should NOT be connected to pin 1 on XLR cables, and pin 1 should also not be connect to the chassis lug on panel mount connectors (snakes and other devices). If your snake has pin 1 tied to the shells on the fan-outs, break the connection. Same with the stage box, no ground lugs on the XLR's should be tied to anything, i.e. the box chassis.
Greg
Cameron Pro Audio.
Page created in 0.045 seconds with 21 queries.
