Author Topic: Multiple monitor jacks.  (Read 1272 times)
Mike Slay
« on: March 24, 2007, 06:18:29 pm »
What's everyone doing to terminate multiple monitor jacks to one amp?
What's the difference between a Monitor engineer and FOH engineer?  Monitor engineers can do both.
Re: Multiple monitor jacks.
« Reply #1 on: March 25, 2007, 05:50:38 pm »
We use one of 3 different ways-depending on the particualr situation.
1: Daisy chain all jacks on stage so only 1 cable ends up at the amp.
2: If there are only 2 runs, we put both runs under the binding posts-may require a little trimming of the strands.
3: Use a terminal strip that is jumpered together on one side and the different runs attach to the other side.  Then a run goes to the amp.
4: Another way is to use a patch bay to select which jacks on stage go to which monitor mix.  These are NL4's with two jacks on each amp output- paralleled at the patch bay jacks.
dB Audio & Video Inc.
Page created in 0.039 seconds with 18 queries.
