Pages: [1] 2 3 ... 6   Go Down
Author Topic: Sabine Navigator NAV4800 System Processor  (Read 42165 times)
The Guy
« on: October 30, 2006, 11:18:50 am »
The good folks at PSW Road Test sent me a nice new Sabine NAV4800 Navigator 4x8 DSP Unit.  I've had the chance to put it to work at a few shows so far and the experience has been positive.
Initial impressions:
Build quality of the unit is fairly solid.  From my understanding, these units are very similar if not identical to the Xilica DLP4080 processors.  It comes shipped with a copy of the control software and all the paperwork.  Right out of the box the unit is easy to navigate (as the namesake would suggest.)  It does seem to take a long time to boot compared to the XTA and DBX Driverack units.
In Use:
I programmed it for my first show via the front panel with ease.  As many of you know, some DSP units are a bit clumsy to work with if you're not programming them on a PC, but this wasn't the case.  The first show was a simple rig...a GL3300 console to the navigator to a couple compact speakers on poles and a pair of SB1000 subs.  The navigator performed well.
I decided to program it for a stereo 4-way system (Turbo Flashlight) via the control interface software (see screenshots below.)  The software is easy to use and is very straightforward.  Enough DSP horsepower is available for any application that I can think of.
In use with the Flashlight system, unscientific listening tests proved that it sounded as good as my usual flavor of DSP (XTA DP226 or Driverack 480.)  I can't say how the EQ filters sounded, as the Flashlight boxes do not require any output EQ as per the factory settings.  I assume the output parametrics sound as good as anything.
The Navigator offers a pretty good DSP package (4x8 in 1U of rack space) for a competitive price.  For those of us who can't afford a Dolby Lake or an XTA DP448, the Sabine NAV series are a good option.  They're also available in 3x6 and 8x8 models.
Good:
-Full featured, affordable DSP
-Flexible Routing
-Software Interface is well designed
-Decent sound quality
-Easy to use
Not as good:
-Encoder wheel on front panel seems fidgety
-Takes longer than expected to boot up
See below for some pics.
-JB
The Guy
Re: Sabine Navigator NAV4800 System Processor
« Reply #1 on: October 30, 2006, 11:19:41 am »
Chilling in my Drive Rack:
index.php/fa/6425/0/
The Guy
« Reply #2 on: October 30, 2006, 11:20:14 am »
Screenshot of the Navigator software with a Flashlight program:
index.php/fa/6426/0/
Matt McCord
« Reply #3 on: October 31, 2006, 02:22:57 am »
When you say that it takes longer than expected to boot, how long does it actually take? I'm considering the NAV3600 for a system that I'm designing and so it would be very helpful to know.  Thank you for your review.
Matt McCord
John Brearton
    • http://www.therightsoundco.com
« Reply #4 on: November 01, 2006, 04:08:38 am »
Matt,
I just got a NAV3600 based on the 3x6 configuration and my need for stereo 2-way plus sub mix. The specs and features are impressive for the price.
I just powered up the NAV3600.
start up: 15-20sec to  fire up with last used program
loading a new program: 15-20 sec
No huge issue but much slower that the Driveracks I am used to.
15-20 sec would seem an eternity if a power issue caused a reboot in the middle of a show... i just tried flipping the switch off and on as quick as possible to see if there was any forgiveness for a less than 1 second loss of power... nope...
You should know that the NAV3600 has only 2 lines of display as opposed to 3 lines on the 4xxx models. This makes it slower to program as you have to page more. I have only powered it up on my desk, paged through the menus and browsed the manual. I created a simple program and saved it with a name but it wont reload properly. I haven't hooked it up to anything yet. It doesn't seem to have any presets so you have to start from scratch (unless some are on the CD ROM). okay i see the website seems to have added presets...maybe new models will come loaded.
Also - i figured it out - it only saves 30 programs and I saved my test program in space 31... somehow it let's you think you are saving to #31 when it doesn't have a space for it.. (maybe it's the temporary storage space?)
I am not slamming the NAV3600, just letting you know what I noticed so far. I do not plan on doing very much programming without a computer interface.
FYI Mine is firmware v5.10... one rev behind
I am hoping the sound quality makes me forget about these EARLY disappointments (mainly because I did not realize there was such a rudimentary screen, an assumption on my part)
John Brearton
The Right Sound Company
Doran Oster
« Reply #5 on: November 08, 2006, 12:52:07 pm »
Sabine is releasing a new firmware rev soon that speeds up the process of loading preset programs.  We recommend using a computer to for the initial Navigator programming and reserve the front panel for tweaks in the field.  The front panel design allows you to select some or all channels and update them simultaneously.  This is much easier than editing one channel and then copying the edit to other channels.
A new computer interface scheduled for release at the end of the year.  It is even more intuitive than the current version.  Firmware and software upgrades can be downloaded free from our website www.Sabine.com and they are backwards compatible.
I look forward to your comments about the sound quality, flexibility, and the quality of the interface.   Call me at Sabine if you have any questions.
Doran Oster,
President
Sabine, Inc.
Phillip_Graham
« Reply #6 on: November 08, 2006, 02:09:47 pm »
Doran wrote on Wed, 08 November 2006 12:52
Doran Oster,
President
Sabine, Inc.
Hey stranger, good to see you!
The mods are going to ask you to add your last name to your profile, just thought I would give you a heads up on that.
New product looks nice!
Jeff Knorr - Cobra Sound
    • http://cobrasound.com
« Reply #7 on: November 09, 2006, 07:04:30 pm »
We have been using the Nav-3600's with Ethernet this summer with great success.  The sound quality has been very good and the built-in FBX capabilities have helped us make the most of some non-ideal situations.  It is possible to make changes through the front panel but it is definitely easier with the help of the GUI.  I'm looking forward to the GUI revisions and can't wait to try them out.
Jeff
PS.  The NAV-3600's work great for using subs off of an aux send (and thus why we originally replaced DriveRack 260's).
Cobra Sound
An authorized Allen&Heath, Ashly Audio, Audio-Technica, Audix, Da-Lite, Danley Sound Labs, FBT, Mackie, QSC Audio, RCF, Sabine, Sennheiser, Whirlwind, and Yorkville Sound dealer.
Rob Spence
« Reply #8 on: November 10, 2006, 11:35:46 am »
Gee, it sure is great to see Sabine represented here  Smile
I have been using PowerQs and GraphiQs for years and love em. I especially like how I can use a computer with multiple GraphiQs at one time even though it is serial (I understand it was the best choice at the time).
I don't understand why DBX did such a poor job of the computer control of the DR260 not to mention there is no ability to control more than one. I guess they don't want their customers to buy more than one unit  Sad
Anyway, I look forward to replacing my Driverack with a Navigator sometime this winter.
Rob Spence
Lynx Audio Services
E-Mail Rob -at- LynxAudioServices -dot- com
Staying out of trouble
  Is easier than
Getting out of trouble
Your local Whirlwind Dealer
John Brearton
« Reply #9 on: November 11, 2006, 01:02:10 am »
oops
John Brearton
Pages: [1] 2 3 ... 6   Go Up
Page created in 0.088 seconds with 20 queries.
