Author Topic: Dimmer and Controller options  (Read 1168 times)
Alfred_Mapanao
« on: May 19, 2006, 12:56:47 am »
Hello. I just acquired 16 Elation Optipars. 12 of them will be mounted on two parbars (6 pars per bar with a 19-pin socapex). What are some good rackmounted dimmers and controllers? I am looking for a long-term solution that I can eventually expand to; whether it is more conventional fixtures or the addition of automated fixtures such as scanners.
So, what is my best approach for a rackmount dimmer? Any certain brands/models that you can recommend? I am looking at the Lightronics 12-channel dimmer with socapex out (forgot the model number). I understand these need a 60A single phase feed. However, since I am not drawing the manufacturer's rating of 10A per channel, would I be safe to use a 50A 220V connector? The reason why I brought this up is because I rarely see a 60A on generators. Mainly the 50A California Standard (CS) plug.
For control, I'm looking at the NSI MC7024. Should I look into something larger?
Please steer me to the right direction since this is my first big jump into stage lighting. I want to do this right the first time. I am mainly catering to rock concerts of up to 1000 people, college events, etc. Nothing big yet. I guess you can say I'm looking for a basic stage wash, but with the option of adding and expanding to some better effects. Does this make sense?
And last, what should I do with the remaining 4 pars? I was thinking of mounting them on a tree with their own 4-channel dimmer pack. What are your thoughts on this? Should I purchase 4 more to mount on another tree and use these as a backwash? So basically my little lighting rig would consist of 12 pars in the front and 8 on the back.
I appreciate your recommendations. Thanks!
 I no longer want to participate in a forum filled with newbies and ego-maniac know it alls. Please delete me from this forum.
len woelfel
    • http://www.party-chicago.com/rentals/rentals.html
Re: Dimmer and Controller options
« Reply #1 on: May 19, 2006, 07:45:49 am »
Gearsource has a few used dimmer racks.  They also have multipin connections.  With the extra amps you could power amplifiers or, if you get moving lights, power them.
Page created in 0.117 seconds with 19 queries.
