Author Topic: long throw subwoofer  (Read 10622 times)
Mahendra Palesha
« on: July 11, 2005, 10:08:05 AM »
I want to build one subwoofer with 18" subwoofer for long throw application. I am thinking to build one of the style of the picture attached. The front & back both r with horns. Is this practical to do so? The suggestions & positive remarks welcome.
Re: long throw subwoofer
« Reply #1 on: July 11, 2005, 10:53:12 AM »
palesha wrote on Mon, 11 July 2005 10:08
If what your hoping to achieve is a subwoofer with directivity control, the way a horn would control the directivity of mids or highs, it ain't gonna happen. Horn loaded or front loaded, at sub frequencies a single box is omni directional. You can gain directivity by making an array of boxes. According to Dave Gunness of EAW a horn loaded sub with a large enough mouth area can simulate what we traditionally think of as long throw because there is a smaller gradient in SPL between a point close to the mouth and a point far from the mouth.
Geri O'Neil
« Reply #2 on: July 11, 2005, 08:09:47 PM »
Mac Kerr wrote on Mon, 11 July 2005 09:53
Mac, I wonder if Dave Gunness would allow that post he did on this subject at the EAW forum to be posted around here somewhere. I've not read a more clearer expanation of why folks perceive horn-loaded sub cabinets to be long-throw. Should we ask him? Then we'd have to get it posted...hmm, that would be some doing now, wouldn't it... Mad
Geri O
"Stagelite Sound...A Pin 2 hot-compliant company"
Gareth James
« Reply #3 on: July 12, 2005, 05:53:29 AM »
I don't know where that designs from but i can't see it working too well. The rear path only looks a few inches longer than the front path, it would probably cancel at many frequencies.
If you're only planning on building one subwoofer you might be better simply building a standard sealed or vented enclosure.
As for long throw, if you built a big enough horn you might project the midbass a little further but then again if you're crossing it out at 80-100hz it won't mke any difference.
What is it for?
Gareth James
Mahendra Palesha
« Reply #4 on: July 12, 2005, 06:19:44 AM »
If i change the front to sealed or tuned port design, what will be the effects. My idea is to give maximum output at 80 hz. Looking at guidance from more experienced friends here.
John Halliburton
« Reply #5 on: July 12, 2005, 07:41:24 AM »
My idea is to give maximum output at 80 hz...
That's just one design parameter.  It's possible to do this for any style of subwoofer discussed so far.  I think you need to ask yourself some other questions:
1.  What are your size limitations for a cabinet?
2.  How many cabinets are you planning to use at one time?
3.  How much talent do you have in cabinetmaking?  Building a horn
   loaded or bandpass cabinet takes quite a bit more effort than a
   vented design.
Finally, one comment about the thread so far, having maximum output at 80hz does not necessarily mean that you need a "long throw" design.
Also, you need to be aware that designing something like this can lead to the classic "one note" subwoofer, known too as the "boom box" effect.  Other parameters and function can be degraded to a noticable point doing this.
Best regards,
John Halliburton
Joe Jones
« Reply #6 on: July 12, 2005, 08:16:50 AM »
Are you really looking for a subwoofer at all? You say you want maximum output at 80Hz, but that's where most subwoofers in large systems are being crossed over to the midbasses. I have my subs crossed to my mains at 80Hz. So I guess the rest of the question is where do you want to use the cabinet other than 80 Hz, higher or lower?
Mahendra Palesha
« Reply #7 on: July 12, 2005, 11:39:37 AM »
Ans : Approx. 6~7 cu. ft.
Ans: Minimum 2
vented design.
4. My friend is a professional PA cabinet maker. That's why i can do it as i want.
Ans: Yes, I agree with ur views,  but my frind likes this kind of bass. So he want me to design this for him.
Mahendra Palesha
« Reply #8 on: July 12, 2005, 11:48:46 AM »
Ans : I will like to use 80hz. as a near center frequency with more towards higher side.
Johan Rademakers
« Reply #9 on: July 14, 2005, 11:00:40 AM »
Why do you want to use an 18" (and any 18" in particular perhaps)?
Your obviously looking for a kickbin, not a subwoofer. In that category most of the advantages that an 18" has to offer will be gone. So why not make a 15" kickbin instead? In which case the HD15 (or HD215) immediately comes to mind.
Mvg Johan
Page created in 0.016 seconds with 20 queries.
