Author Topic: disadvantages to active speakers  (Read 11546 times)
[x]
« on: April 29, 2005, 10:44:10 pm »
What disadvantages are there to using active (powered) speakers instead of passive speakers? Weight difference is one area that comes to mind.
I've said and written things in the past that I wouldn't throw away in my own trash can for fear that you'd find them. My name is mud.
Wade Biery
Re: disadvantages to active speakers
« Reply #1 on: April 30, 2005, 12:43:21 am »
Another obvious one is that if it breaks, TWO things go down for repair.
DanDraper
« Reply #2 on: April 30, 2005, 03:52:23 am »
u have to run 2 cables to each speaker....
however, u have less to carry around and less space taken up on stage because there are no amp racks, plus protection circuitry and crossover etc. are designed specifically for the amp/ driver combo, so can be better
hope this helps
Dan
http://www.jerichosound.co.uk
James Leece
« Reply #3 on: April 30, 2005, 04:54:13 am »
STILL wrote on Sat, 30 April 2005 05:43
On the other hand, with passive setups you can have 2 or more speakers being powered off one amp. So if one amp goes down completely, you lose two speakers as opposed to just one.
« Reply #4 on: April 30, 2005, 08:58:46 am »
The biggest issue is, what would be the best type of speaker for the job First. Then look at what's available and what would make better sense.  Is this for install-portable-flown-ground-cost-size-coverage etc.
Making a blanket statement is kind of like asking what is better a car or a pickup?  After you determine you need,then you can ask what is better Ford Chevy Toyota etc. Then you choose your color etc.  Your particular need come first!
But to answer your question is there are advantages and disadvantes to active and passive speakers, it all depends.
dB Audio & Video Inc.
Brian Adams
« Reply #5 on: May 01, 2005, 05:01:06 pm »
Here's a few that I can think of:
Active:
~Generally more efficient on power
~No amp racks, saves space onstage and in the trailer
~Don't need speaker cables
~As many mixes as you've got speakers, as long as you've got the sends
~Most have a built-in LP or HP crossover, which can be handy sometimes
~Some have built-in mixers, which work for small stuff
~Preset delay and crossover points, some have a preset EQ curve to correct frequency response
~Built in limiters
~Can be easier to power than large amp racks when there's not adequate power
Passive:
~Possibility for better biamping/triamping
~Easy to add more cabinets on the same amps
~Ability to run several cabinets on one amp channel
~Only one cable to each cabinet
~Can save cable with multiconductor speaker cables (NL8 into triamped mains, NL4 out from mains to sub)
~Usually easier to deal with equipment failure
~No IEC cables to slip out of the cabinet during the show
~Locking connectors (ie- Speakon)
That said, I think that active systems are great for small-ish setups, maybe up to 3 mains/subs per side.  Anything more than that, and you're better off going passive.  Unless you've got something like a Milo rig (or something else by Meyer), or a powered Vertec system, or something similar, but that's a little different.  One of the biggest advantages of active systems, for me, is the ability to be able to make do with less power than a similarly sized passive system.  It can be a pain to run two cables to each cabinet though, especially when there's lots of cabs.  Built in limiters great, they help to keep you from blowing things up.
In my experience, powered cabs aren't significantly heavier than similar passive cabs (maybe 20%), but the total weight of a passive system is much less without those amp racks.
B.
« Reply #6 on: May 01, 2005, 07:00:43 pm »
BHFProfessional wrote on Fri, 29 April 2005 21:44
This is not easy to answer. Even the weight issue depends on what you are comparing to.... You should consider the weight of the total system.
I am a huge fan of active speakers because I have seen what can be done. I consider using passive speakers a little like the old days of Hifi when you had to be smart enough to buy components that would work well together, and know how to hook them up etc.
I have worked closely with a few very good speaker designers. I will trust them to tweak the crossover any day over leaving that to the system operator to second guess. There will be abuses, like certain active speakers that are voiced to sound better at POS than in actual use... but that happens with passives too.
I suspect some day we may look back and reminisce about passive speakers. Of course I could be wrong... Cool
 https://www.resotune.com/
Tune it, or don't play it...
Bud Bolf
« Reply #7 on: May 01, 2005, 07:03:41 pm »
 My complaint in a nutshell.
What do you do when the Internal Power Amp fails? The Active Speaker is dead, dead, dead! The Manufacturers will not add a Switch into the cab, that will let you bypass the Internal Power Amp, and still use the cab via a Spare Power Amp.
I understand that as a Manufacturer, it is not good to add cost to a unit so that it may still be used if a portion of it Fails.
But let's face it they do Fail. Only God is perfect 100% of the time! For Manuf. sales, Failures are never part of an Ad!
If my Passive System looses a Power Amp, I have options.
I can use a Spare Amp, or use a Guitar and or Bass Amp, Bridge one of the other Amps, take one Side of my Monitor Amp.
Because the bottom line, is to ALWAYS get through the GIG!
The following day, it's a lot easier to rent or Borrow, an Amp, than a Active Speaker Cab!
When Active Speaker cabs provide me with an option to get me through the night, then I'll think of putting my Faith and Money as well as a Gig into them!
Until then I'll stay Passive, Flexible, and able to get through the Show!
 This is of course considering that you know how to set your Gains and are not Blowing up Speakers, just dealing with Amplifier Failures.
My 2c
 Bud
Rob Timmerman
« Reply #8 on: May 01, 2005, 09:35:38 pm »
True, if the internal amp fails on an active speaker, the speaker is no longer usable.  But passive speakers have many more failure points than do active speakers.
A biamplified active speaker has the following potential failure points:
Drivers
Internal electronics (including amplifiers)
Power cable
Signal cable
The equivalent externally powered speaker has the following failure points:
Drivers
Speaker cable
Amplifier (possibly 2)
External DSP (or crossover + limiter)
interconnect cables (including patch panels)
Power cable x2
Signal cable
Unless you do something stupid, you aren't going to blow drivers.  And given modern manufacturing, failures in amplifiers and drive electronics will be low.  The big issue in my mind is the cable, as that is normally what fails.
If you're worried about failure, full redundancy with active speakers is easier and less expensive than with an externally powered cabinet, as you need less spare equipment.
Wade Biery
« Reply #9 on: May 01, 2005, 09:53:51 pm »
FunkyJim wrote on Sat, 30 April 2005 01:54
That only makes sense if it takes the speakers with it when it goes, (which obvioulsy does happen sometimes) but otherwise you only need to replace one thing.
Myself I still really haven't heard active speakers that stand up sound-wise against a good or even decent passive speaker/amp system, but I admit limited exposure to them.
Page created in 0.028 seconds with 18 queries.
