Hi folks,
It appears that I am (finally) going to be able to put a Yorkville A4.4 up against a QSC PLX3402 for both (rudimentary) bench testing as well as a more comprehensive listening test. Here are my plans wrt to setup:
For each amplifier:
Ch 1 - drives (1) EAW SB250
Ch 2 - drives (1) Yorkville Unity U15 in passive mode
We'll use the (Ashly 4.24C) processor to handle crossover duties as well as EQ duties (I'm thinking I'll take (and save) a transfer response curve in Smaart of the tri-amped performance of the system (it's technically a 4-way rig, but only 3-way active, since the MF and HF are passively crossed over) and then use that as a reference when EQ'ing the U15s in passive mode. Once we are satisfied with the sound, we'll then use a test tone (I'm open for suggestions here as to what frequency to use - note: both amps use switching power supplies) to match output levels and then commence with the listening portion of the test.
As for the bench portion of the test, since the amps either a) operate in the sub-500Hz region or b) would operate in the sub-500Hz region, my main interest is in their power levels down to, say, 30Hz. My question (and the prime reason for this post) concerns
how to conduct those tests. A fellow LABster (Phil Ouellette), who will be helping me and participating in this A/B comparison, has a signal generator that will let us pick what frequency to send to the amp. The natural question then is, What do we use as an indicator that we've reached max output power? The amplifier clip lights? AFAIK, we've no way to measure THD+N
Also, I should note that Phil has (as I recollect) (2) 400W, 8-Ohm resistors and (1) 800W, 4-Ohm resistor, so max power output tests at different frequencies will have to be taken at 8-Ohms, though I
do planning on wiring up the resistors for a 2-Ohm load and connecting it up to 1ch of the A4.4 (which is only rated to 4-Ohms) and seeing just how it responds
FYI, the bench tests are primarily for 2 reasons:
1) To see how the PLX3402 responds in the lower frequency ranges - it's younger brother, the PLX1602, didn't fair all that well, as the 20Hz output was ~65% of the 1KHz output...
2) To see how the Yorkville A4.4 handles a 2-Ohm load, since you never know when an amp might die on you (*knocking on wood*) and you need to "double up" on an amplifier's load.
One other note, we plan on using a VOM to measure output voltages (though Phil might bring along his o'scope), so if the recommendation is to use pink noise (I have Bink's Audio Test CD), would averaging the measurements yield fairly good test results?
I appreciate your thoughts/comments/opinions/suggestions! Cheers!
Charles Johnson
PS A question that has been nagging me every since Bink's Amp Shootout is, assuming switching power supplies were being used, what causes an amp, when pushed towards the limits of its output rails, to produce more power at higher frequencies than at lower frequencies? Perhaps Bob Lee, John Roberts, and some others can chime in? Thanks!
