Author Topic: dispersion  (Read 2620 times)
Chris Cowley
    • http://www.humhead-digital.co.uk
dispersion
« on: July 07, 2004, 01:57:46 pm »
has anyone got any dispersion graphs for LABs?
GO YOU BIG RED FIRE ENGINE!!!!!!!!!
Mark Seaton
Re: dispersion
« Reply #1 on: July 07, 2004, 02:45:13 pm »
Dispersion is entirely dependent on the number of boxes.  You can determine a lot just by dimensions.  The orientation of the sub may have some effect, particularly with placing 4 together with the mouths flaring out from the center, but if it did have any effect, the effect would mostly be noticed above maybe 50-75Hz, and most easily examined near 75Hz.  If someone wants to do some reasearch, I would test some different configurations at ground level directly on axis, 90 deg, and 180 deg at maybe 4 meters or more.  If you find some significant attenuation at 90 degrees, you can start moving forward and watch to see where you hit -6dB relative to on axis for a given frequency.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." - Daniel H. Burnham
Page created in 0.024 seconds with 19 queries.
