Author Topic: LSP dxf files converted for use with 18mm plywood  (Read 4588 times)
Jeremy Bridge
Re: LSP dxf files converted for use with 18mm plywood
« Reply #10 on: July 08, 2004, 10:24:54 am »
I also should have noted, Ernie, that these plans are MUCH easier to build completely in metric.   The imperial measurements are ugly.
Perhaps you could throw that in the blurb.
Ernie Black
    • http://www.standingstone.com
« Reply #11 on: July 08, 2004, 10:52:33 am »
So noted!
Ernie Black, Code Warrior
ProSoundWeb Forums Webmaster
PowerSound
    • http://www.powersound.be
« Reply #12 on: July 11, 2004, 06:08:31 pm »
I've a question about your converted plans.
How did you insert the baton for the grill ?
Are this batons showed on the new plans ?
What are the dimensions of these ? Are they making the whole contour of the throat ? And what about the Mouth Cross Brace ?
Do you have any pictures of YOUR builded LABHORNS ? With and without the grill ?
Tnx
Ooooooooooouuuuuuuuuuuuuuhhh, What does this button doooooooooooooooooooooooo ?????
Jeremy Bridge
« Reply #13 on: July 22, 2004, 01:51:42 pm »
The batton is simple.
Its just a frame of 18mm x 18mm  strips of wood that are set back into the mouth 2cm.
The braces, and flare have been pushed back a tiny bit to acompany the batton and grill, however there should be little to no difference in sound.
I should have pictures shortly.
Page created in 0.09 seconds with 20 queries.
