Author Topic: Sound Quality  (Read 5273 times)
andreas
Sound Quality
« on: April 26, 2004, 11:00:40 am »
Dear All
The virtues of the lab sub as pure sub woofer is beyond question. But can anyone comment subjectively on the sound quality if used with proper eq up to - lets say - 200 Hz. The roll off starts around 150 as I can see from the published response plots.
Cheers
Andreas
Brad Litz
Re: Sound Quality
« Reply #1 on: April 27, 2004, 02:56:44 am »
See v3.0 predicted response here:
http://srforums.prosoundweb.com/index.php/m/1364/500/5bee6ea c8c4aab7c978178d0573ffc17/?SQ=c934a917d19af4e2afe4dea4c5c2fe 31
Brad Litz
Brad Litz
Re: Sound Quality
« Reply #2 on: April 27, 2004, 02:59:45 am »
v3.0 looks even better in AJhorn analysis:index.php/fa/39/0/
Brad Litz
andreas
Re: Sound Quality
« Reply #3 on: April 27, 2004, 08:09:40 am »
Thanks Brad
response curve looks mighty good, it would be cool though to get som listening impressions of the horn up to 200Hz. As it makes some freedom when considering construction of a horn loaded top box.
Cheers
andreas
Brad Litz
Re: Sound Quality
« Reply #4 on: April 27, 2004, 08:24:05 pm »
I'll measure and post the response when I get them finished.
Brad Litz
Sound Construction
Re: Sound Quality
« Reply #5 on: May 18, 2004, 02:02:30 pm »
dude... they're subs
Jens Droessler
Re: Sound Quality
« Reply #6 on: May 23, 2004, 11:02:30 am »
30 to 200Hz is a big stretch. That's why the LABsub is called LABsub. Best solution would be a filler cab that can do 80 - 200Hz in really good quality. I don't think that it's good idea to force a linear plot by EQ.
"The man who trades freedom for security does not deserve nor will he ever receive either."
Brad Litz
Re: Sound Quality
« Reply #7 on: May 23, 2004, 11:09:03 am »
Jens Droessler wrote on Sun, 23 May 2004 10:02
Two LABsub v3.0 no EQ.
index.php/fa/111/0/
Brad Litz
Sound Construction
Re: Sound Quality
« Reply #8 on: May 24, 2004, 01:57:56 am »
Brad,
I don't have a lot of experience reading graphs like this, so I have a few questions. was the source matereial a full frequency burst or a sweep? If it was a full frequency burst these results would mean that the amp and driver are able to simultaniously reproduce lower (frequency's requireing long slow excursions) as well as the faster transients up to 200 hz at approx the same efficiency.
What kind of amp did you use for the tests?
If this is the type of frequency response that can be expected in real world it would mean that the low mid of a 4 way system (like you would have if you matched a set of labs with some EAW 650's) could be eliminated and with a simple crossovers adjustment. Do the measurements you've gotten so far indicate that the Labsub could/shoule be used to cover such a large frequency range in a live sound application?
I saw the new web page for v.3. Your craftmanship is simply astounding.
Brad Litz
Re: Sound Quality
« Reply #9 on: May 24, 2004, 03:16:41 am »
The test signal was a full frequency maximum length sequence or MLS. It is basically a pseudo-random sequence of pulses. The MLS has a quasi-flat power spectrum. The spectrum envelope follows a square(sin(x)/x) law and falls by about 1.6 dB at 1/3 of the sampling rate (48 kHz).
The amp was a Sony TA-E9000ES.
http://www.sel.sony.com/SEL/consumer/ss5/home/homeaudioes/es poweramplifiers/ta-n9000es_specs.shtml
The measurements indicate a 12dB/octave roll off beginning at 200 Hz. A 12dB/octave low pass filter placed at 200 hz would result in a 24 dB/octave acoustic response. This would match a 24 dB/octave 200 Hz high pass into the midrange.
Brad Litz
Page created in 0.034 seconds with 19 queries.
