Author Topic: Our light system pics  (Read 6583 times)
Mike Pyle
Re: light system pics
« Reply #10 on: April 25, 2004, 10:49:40 am »
Craig Leerman wrote on Fri, 23 April 2004 05:58
 http://www.angelfire.com/biz/harborsound/images/Lights01.jpg
I like this look. How do you anchor the truss? Is it just sandbagged, or do you have a base or ropes that aren't visible?
Mike
Mike Pyle
Audiopyle Sound
707-315-6204
Dealer: Yorkville, EV, QSC, RCF, KV2, FBT, EAW, Danley, SLS, Turbosound, dBTech
 APB,A&H,Audix,Shure,Powersoft,RoadReady,K&M,Ultimate ,Global Truss,DENON,Chauvet,Elation...
len woelfel
    • http://www.party-chicago.com/rentals/rentals.html
Re: Our light system pics
« Reply #11 on: April 25, 2004, 11:44:13 am »
SamIam89 wrote on Sat, 24 April 2004 20:40
On most info sites, they talk about each channel going from 0-255. The board that comes with the package goes from 0-100. Is that the same thing only on a different scale?
How 'bout some specifics?  What board, etc.  You're probably correct in assuming so.
And you'll probably get a better response by starting a new thread rather than putting a new subject in an old one.
len woelfel
« Reply #12 on: April 25, 2004, 11:46:31 am »
Mike Pyle wrote on Sun, 25 April 2004 15:49
Mike
Those are probably anchored to a base plate, a big, heavy piece of metal with wholes in it for bolting truss ends to.  But they should also be tied off at the top as nothing is 100% secure on one point.
Craig Leerman
Truss bases
« Reply #13 on: April 26, 2004, 01:11:19 pm »
I use 2 different methods to stand the truss upright.  The first is a simple flat baseplate. I have a pair made of diamond plate aluminum and 2X2 aluminum tube. I also have a pair of wooden baseplates made of 3/4" plywood and 3/4" plywood runners.
The flat baseplates are used when I stand up two sections (16' high total) of single hung truss.  I bolt the baseplates to the truss and weigh them down with about 150 lbs of sandbags or stage weights.
I also have a pair of wooden boxes I built. I wanted to have different heights of truss standing up, and a single 8' section didn't seem tall enough for me, so I built 3' high boxes. These boxes are made of 3/4" plywood  and 2X4 bracing, and have an open back so you can reach in an get to the bolts.  In use, I stack about 75 lbs of sandbags or stage weights in the box for stability. I only use a single 8' high section with a box base.
I have only used the truss standing up on sturdy stages at corporate type shows. I have not had a problem of the truss swaying or being indanger of falling or bumped into. I will only stack two section max on a baseplate and one section on a box.
Craig
Dave Nolan
Re: 255 query
« Reply #14 on: April 29, 2004, 07:56:01 am »
Hello there
The DMX signal that your controller will send to a dimmer / fixture will basically have a value of anywhere between 0 and 255.
The 0-255 range is inherent in the actual structure of the DMX signal.
Controllers will be either from 0 to 10 or 0 to 100 because we can understand these ranges easier than 0 to 255.
If you actually look at the DMX output with a fader half way up, you will see an output of around the 127 - 128 mark.
Have a look at http://www.dmx512-online.com for one of the best explanations of DMX I have seen.
Cheerio!
Dave
Page created in 0.046 seconds with 18 queries.
