Author Topic: Weidamark Failures  (Read 4417 times)
Jeffhtg (Jeff Kenney)
Weidamark Failures
« on: February 10, 2011, 09:23:02 AM »
I'm starting to experience LED failurs on Weidamark 64 10mm par cans. It is always the blue. They start by flickering in small groups of 3-4 or so and then soon they all stop working.
In Weidamark's defense these things have been used for 2+ years straight every night basically. So they got some hours on them.. however it certainly falls short of the 50,000 hour estimated lifespan. Arguably not cheaper than a par can - altho it would come close replacing the gel every week or two. (not figuring in the power savings as I do not have to pay for Kw/H)
I currently have 3 out of 8 cans with no blue at all and 1 flickering when I touch it.
James Feenstra
Re: Weidamark Failures
« Reply #1 on: February 10, 2011, 11:15:33 AM »
probably a loose connection on the pcb inside the unit somewhere...common problem with LEDs I've found, especially when they travel
had a bunch of elation units loose colors the same way...simple loose connection
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Page created in 0.038 seconds with 23 queries.
