Author Topic: Are older toroidal amps better for subs generally?  (Read 13468 times)
Iain.Macdonald
Re: Are older toroidal amps better for subs generally?
« Reply #10 on: September 23, 2011, 01:20:56 pm »
Quote from: Peter PKN Controls
The price of this solution is you need to have at least several tens of Volts above the actual output range. Most of the conventional amps can not work this way due to the unaffordable extra losses... some of the switching amps have this feature and gives tight, very precise phase controled low range for those who like it.
Péter
Quote from: JR reply
It is very impractical and generates way too much waste heat to have and not use, tens of volts of power supply rails.  By switching amps are you speaking of class D amps with switching output stages or linear amps with switching power supplies? Class D amps use saturated output devices so all of their PS voltage is always used, switching supply amps come in many flavors.
Oversized amps that never clip can sound good, because they never clip.
+1 to Peters post.
JR, I am not sure whether you are agreeing or disagreeing with the quote, especially the first sentence. What about tracking SMPS? The rails are usually held at very low level.
Iain.
« Reply #11 on: September 23, 2011, 02:59:38 pm »
+1 to Peters post.
Iain.
I am not sure either? What technology he is speaking of? I expect I will find out. ;D  A tracking supply that is always tens of volts hotter than the output seems kind of wasteful.
Back in the '80s I designed a small amp with a tracking supply, that was capable of 4x peak, the continuous output power. One quirk of my design, that I suspect other similar designs may share is that the rate of change of the tracking supply directly impacted signal purity, so for acceptable distortion the power supply rate of change was slowed down. To keep up with signal transients, the supply had to be programmed with some HF lead and safety margin so the PS will be there in time to support fast audio signal transients. Of course this reduces the efficiency benefit available. Selectively making the PS anticipation lead, sensitive to rate of change allows for decent efficiency when playing LF content, but it was a juggling act between several variables.
I suspect the technology available in the decades since I last played with this is better, both regarding PS speed and output stage rejection of PS artifacts (Miller capacitance in bipolar output devices was a vector for distortion from high PS edge rates). I used a pretty low tech approach for my variable rail and only made modest power, but it was enough to reveal the difficulty to execute this approach well (there is no free lunch).  I would expect similar issues in a big dog tracking rail amp to optimize for both low distortion and fast transient response (like maybe a bunch of extra JIC volts in the tracking PS). Tone burst testing should reveal any issues from a PS not keeping up. Steady state sine wave testing should be relatively easy lifting for this approach.
I am generally supportive of this technology, if that is what we are talking about (analog amp with switching tracking supply). it wasn't clear from the post.
Another amp idea I never got around to breadboarding is to use a variable intermediate rail in a class G/H amp. If this lower rail is regulated to deliver high  efficiency based on actual waveforms, and large transients could simply be handled by the high rail using the existing rail commutation inherent in that topology, we could milk some more efficiency from the good old class G/H without any performance trade off (just some extra PS complexity cost). This intermediate rail could be back slope regulated (kind of like a light dimmer once or twice every mains cycle) so relatively cheap and low tech. I haven't been in the amplifier trenches for a while so my apologies if somebody is using this variant too.
This is all kind of mooted by class D getting better and cheaper. A tracking switching supply, wrapped around a linear amp, could also be thought of as a variant  class D amp that uses the linear amp as an expensive output filter.
One more wing nut idea of mine, that I never bothered to breadboard was to drive one speaker lead with a dirty class D amp, and then drive the other speaker lead with a low voltage correction signal to subtract out distortion from the cheap class D amp, but this too is impractical. Cheaper now to just make the class D amp better.
Bigger amps that don't clip are always good.
Richard Stringer
« Reply #12 on: September 23, 2011, 03:15:37 pm »
You're able to get a cleaner sound and not have to clip an amplifier by using an amplifier which can output 2x the continuous average power rating of your speakers or subs, and then operating the system at a lower level though aren't you, headroom it's called isn't it. I know for dance music a lot of engineers have to be careful because of the massively compressed tracks with sustained sub basslines, so they use amplifiers which use no more than 2x the speaker cab's rated continuous power. Am I right in saying that with rock music and country music because it's live sound and no pre-recorded and compressed to death, that you guys can get away with using amplifiers capable of outputting maybe 3x the speaker cab's continuous rating so you have masses of headroom? Or do you guys, because you can afford the speaker cabs, bring quite a bit more system than you'll need so you can achieve the same spl levels and not have to run the system so hard?
Stu McDoniel
  • Central Wisconsin...USA
« Reply #13 on: September 23, 2011, 11:00:23 pm »
I've always kind of wondered why toroidal transformer amplifiers are generall better for subs than switch mode power sply amps, and I kno, or rather think, that amplifiers like say the Crown XTI series aren't great on subs because their power supply isn't big enough and can't extract enough power out the wall to cope with the sheer power thats needed for running subs with styles of music that have sustained basslines. Am I right?
A Peavey tech guy told me that generally a lot of switch mode amps are rated in peak power and not continuous average power because the switch mode amplifier in general isn't capable of extracting as much power as toroidal amps, and so rate their switch mode amps in peak ratings because if they rated the actual continuous average power the power output figures, meaning specs, would look pretty shite compared to old school toroidal amplifiers like the Crest CA18, Crown MA5002, Crest 9001 etc..I was also told that older amplifiers have either bigger power caps or more of them so to store enough power ready for when it's needed.
What's your thoughts guys on why in general, toreoidal amps are better for sub than switch mode amps?
Here is a nice paper on amplfier power and loudspeakers
http://www.eaw.com/Info/EAW/Technical_Papers/AmplifierPower.pdf
Richard Stringer
« Reply #14 on: September 24, 2011, 04:07:57 am »
Thanks Stu, I knew about headroom and power handling anyway, I was just wondering if you guys bring more rig than you need or use more powerful amplifiers to achieve the headroom.
Peter PAPP
    • PKN Controls
« Reply #15 on: September 24, 2011, 07:24:56 am »
+1 to Peters post.
Iain.
I meant two different state of operation when reactive energy occurs, i found very important how the amplifier recycles (if able to do that and not dissipates) reactive back energy.
1. The amplifer controls the reactive amount of energy by forcing the momentary output voltage on the voice coil. If you have a good class-D amp changes operation from buck mode--->>boost mode and pushes back energy into its DC rail capacitors. The Voltage of DC rail increases but the actual value of coil Voltage NOT. This amount of recycled energy could be reused again the next buck-cycle.
2. In a class-AB linear amp the reactive energy usually creates extra heat losses, sometimes over the safe dissipation factor of output devices. In a Class-H amp there are separation diodes between "steps" which effectively blocks the reverse energy flow.
If the AB class amp has enough momentary headroom in heat dissipation on its output devices It would be able to perfectly handling the situation and would be the best sounding solution despite of heavy heat losses. However I have not seen any of those analog amps.
The general problem is handling speakers as a resistor while they are not. Same is the situation with the tracking amps (class-TD) where switching preregulator used for coarse voltage production of the fine class-AB endstages.
This method has even lower losses than Class-H and distortion values are extremetly small with RESISTIVE loads.
Since these circuitry use almost always a simple buck-type switching preregulators as the reflected voltage (due to the reactive back energy) exceeds the coarse Voltage value (typically ~10V) the amp completely loses control of its output.
The best solution would be extending the simple buck to a synchronous buck converter which is able to recycle reactive energy by mode changes however it would makes twice as complicated the already two stage circuitry.
About the clipping of bigger amps: I think this is a very important feature that NEVER CLIP. When the signal reaches output rails means loosing control and the clipped signal sharply increases its rms value killing voice coils by elevated heat. When the amp is really big this effect is even more faster.. so for reliability aspects proper built-in limeters are very important.
P.
« Last Edit: September 24, 2011, 07:27:03 am by Peter PAPP [PKN] »
PKN Controls // PKN Audio
www.facebook.com/PKNaudio
« Reply #16 on: September 24, 2011, 01:13:57 pm »
I am familiar with the hypothetical premise of back EMF from loudspeakers driving back into power amp outputs. Mostly from advertising material associated with class D amps.
I am not familiar with solid characterizations of how often this occurs with normal signal playback. I have a judgement about magnitude of load angle (from designing amps that didn't melt), but no empirical data to provide here.
If the triggering event for this back EMF is amplifier clipping, I think we all can agree that this is best avoided, and behavior around clipping is underestimated as a source of sonic differences between sundry amps.
Perhaps some serious speaker guys reading this can contribute some practical input about reactive energy available from their loudspeakers.
PS: I notice you are making a 3 phase powered amp. That is sweet if you can do it, but it seems with PFC you forfeit some of the benefit from the overlapping phases.
Scott Wagner
  • Richmond, VA
« Reply #17 on: September 24, 2011, 01:59:33 pm »
Rig size decisions are based more upon coverage.  SPL considerations are usually considered in rig selection (ie: which system to bring), as opposed to how many speakers to deploy.  The headroom increases are more a function of having a less compressed signal - less average levels equals more capacity for peaks.  This is precisely why DJs have a reputation for releasing the magic smoke.  The exact same rig can get much higher levels for live music that it can for over-compressed DJ tracks.
Scott Wagner
Big Nickel Audio
Scott Wagner
Big Nickel Audio
drew gandy
  • Chicago and burbs
« Reply #18 on: September 24, 2011, 03:10:26 pm »
Do you make any amplifiers for export to the US (ie 120VAC operation)?
Arrogance is usually far worse than ignorance. But every once in awhile they swap places.
Richard Stringer
« Reply #19 on: September 25, 2011, 04:19:07 am »
Scott Wagner
Big Nickel Audio
Yeah most dj's I know run levels into the red lights, I personally think it's so stupid, I mean these dj's either don't know you get a cleaner sound and better sound quality when you don't clip the system, or they just couldn't give a sh*t. Personally I think it's because most couldn't give a sh*t. I've been a dj since 1993 and I never clip a system, I would rather have better sound quality than more spl.
Page created in 0.081 seconds with 24 queries.
