Pages: 1 [2] 3  All   Go Down
Author Topic: PKN 3PHASE-40K  (Read 18532 times)
Peter PAPP
    • PKN Controls
Re: PKN 3PHASE-40K
« Reply #10 on: September 20, 2011, 11:30:48 am »
Not available until a projected Q1/2012.  No apparent regulatory agency listings.  Non-standard power connector and no identification of related power cord termination.  No identification of how the power ratings specified were obtained or what they represent (and since the amps apparently won't be available for some time, if they are based on predictions, prototypes or production units).  These may turn out to be an interesting option for some applications but what is presented seems more a concept.
I'm a little surprised that given some of the seemingly likely applications there seems to be no AES3 or networked audio input options.  I'm also curious as to what the DSP option noted actually is and does, there are no apparent slots for a user installed card so it would seem to be an internal module.
Tim, the specifications note an input sensitivity of 0.775VRMS/0dBu or 2VRMS/+8dBu selected from the menu, however they don't note a maximum input level.
Dear Sirs,
The power connector of PKN 3PHASE series is a modified MIL-DTL-C5015 standard circular, hermetic metal part. Similars used on lighting equipments and few speakers. May it will not pass CE regulatory approvals without problems which are under way but we will see.. We have also a second optional connector possibility but that would be more costly.
About the worries of reliability: the 40K version has doubled 20K modules (booth PSU+Endstages) also the built-in DSP has parallel processing and twin internal powering. The internal PSU modules which are segmented into parallel sections too have separated fusing per section so in case of one module fault (or a missing power line ;-) the unit remains operational.
Our new power conversion technology with these levels of compactness and power density was not really present in commercial/professional equipments. It is something new.
The input sensitivity can be set in 0.5dB steps anywhere from 0.7Vrms up to 10Vrms (for those who more like to see Voltage levels instead of dBs). Inputs survive 15Vpeak Voltage without significant distrortion, clipping or failure.
DSP board is internal and not accessible by the user.
Later i am planning to share more informations about the features and technology.
All the best
Péter
PKN Controls // PKN Audio
www.facebook.com/PKNaudio
Re: PKN 3PHASE-40K
« Reply #11 on: September 20, 2011, 11:36:32 am »
Dear Sirs,
All the best
Péter
Greetings, Peter-
Thank you for contributing the additional information.
Have fun, good luck.
Tim Mc
Brad Weber
  • Marietta, GA
Re: PKN 3PHASE-40K
« Reply #12 on: September 20, 2011, 12:13:36 pm »
Peter, thanks for the response and additional information.
Jason Joseph
  • Vibrant Soundz
    • VibrantSoundz.net
Re: PKN 3PHASE-40K
« Reply #13 on: September 22, 2011, 01:24:48 pm »
http://www.youtube.com/watch?v=LJHBrNR-z9M
If you want to see one live in action...
Iain.Macdonald
Re: PKN 3PHASE-40K
« Reply #14 on: September 23, 2011, 01:34:15 pm »
Hi,
Ah the spy pictures are beginning to surface! In the short time I was on their stand, it was fun to observe the "competition" coming to have a look at this amp. For those who were given the privilege of seeing the inside, let's just say, that this is not your average amplifier. It makes some other hyped products look "agricultural".
Peter: With regard to the connector and CE issues. Why not have a captive cable with standard 3Ø CEE connector.
Iain.
paul bell
Re: PKN 3PHASE-40K
« Reply #15 on: September 24, 2011, 12:23:57 am »
This is all very interesting. I'd like to learn more about it.
I'd need it to run on 208 Volts, single phase. Two channels at 3,500 watts into 4 Ohms, one channel at 8,000 watts into 2 Ohms and one channel at 200 watts into 8 Ohms. It should be a walk in the park for an amp with these ratings. It's not as deep as the Powersoft amps but the power plug looks very long. 90 degree power inlet plug? It'll also need at minimum a CE certification.
Peter PAPP
    • PKN Controls
Re: PKN 3PHASE-40K
« Reply #16 on: September 24, 2011, 05:23:44 am »
Hi,
Iain.
Dear Iain,
The powercord used as 1/3 phase operational selection in the following method: There are two prower cords for each amplifier, one is for the three phase and another for the single phase operation. So the user does not need to care anything else just plug in the proper connector and the unit is working. The power supply has automatic voltage sensing so it reconfigures itself for the optimal operation.
The power input connector has five pins, 3 smaller and 2 bigger. When operated on 3 phase the smaller pins used as line inputs (L1+L2+L3) line inputs and one bigger pin as the protective earth (PE). This is four wires total which means relative skinny cable.
When operated on single phase the three smaller pins connected all in parallel by the single phase power cable and used as line input (L) with three times of the current capability of the individual smaller pin and another bigger Neutral (N) connector used as well as protective earth (PE)
On single phase much more stronger line is required and there is no the advantage of the three-phase small ripple goodness however the amp is still operational at very high power level.
The amps would work even at 90Vac(single phase) but the charging capabilities of power supply drops dramatically and also the current draw limited to 63A(long term) which enable only much lower output operation.
Better to use the 180V...250Vac range on single phase but the best is the true three phase HV of course.. ;-)
Input current is forced to follow the shape of line Voltage in all operational conditions called Active Power Factor Correction. Another feature is that the maximum current draw could be set for different fuses by the user from the front display or even from remote (over ethernet). Ironically the biggest PKN amp has the lowest inrush current up to date :) compared to our other units. The start-up process is also user configurable, faster start-up means higher inrush current.
There are many more styles of the applied power connector set, 90degree and different strain relief versions with longer or shorter sizes.
Péter
Jason Joseph
  • Vibrant Soundz
    • VibrantSoundz.net
Re: PKN 3PHASE-40K
« Reply #17 on: December 07, 2012, 04:01:01 pm »
Any updates?!  :D
Stu McDoniel
  • Central Wisconsin...USA
Re: PKN 3PHASE-40K
« Reply #18 on: December 07, 2012, 10:05:17 pm »
New Three Phase 40000Watts amplifier from PKN Controls  :o
http://www.pknc.com/3phase_eng.html
How good would be the low frequency response due to the 3 phase powering?
Anybody has ever seen similar equipment?
ASP.
Price?
Uwe Riemer
Re: PKN 3PHASE-40K
« Reply #19 on: December 10, 2012, 09:40:00 am »
Price?
List 14125 Euros excl. VAT in Germany
Re: PKN 3PHASE-40K
Pages: 1 [2] 3  All   Go Up
Page created in 0.093 seconds with 22 queries.
