Author Topic: swapping SRX horns  (Read 3134 times)
Steven Gustafson
swapping SRX horns
« on: January 27, 2011, 11:02:50 AM »
Sorry for the re-post.  No responses in the lounge, might need more experience.
Just wondering, I'm looking at purchasing some SRX 725s over twin 718Ss but I'm wondering if I could swap horns later on.
Because they are the same size, etc.  Can I swap the standard 75x50 horn with a 60x40 model 2385A?  Would I run into alignment, crossover or other problems?
Also, has anyone ran 725s bi-amped giving the lows 3200 watts vs. 2400 watts?  Any problems?  The 2265 driver is a 1600 watt driver right?
Bob Leonard
  • Boston, MA USA
Re: swapping SRX horns
« Reply #1 on: January 30, 2011, 06:58:24 AM »
Steven,
I had asked JBL this question many years ago when purchasing my first pair of 725's. I was thinking at the time that if I may need narrower coverage patterns for larger venues, or when running pairs. What I found in practice is that this has not been the case.
What I was told by JBL is that the pattern can be narrowed with no ill effects, however, the pattern can only be narrowed by another 15 degrees down from the factory 75 degrees with the proper horn.
Take a look at the VP series and you'll note there are two options for the horns in every type box. The drivers for the VP series are virtually identical to the SRX series and in the VP series all other components are the same. So, based on what I know and have been told by JBL I would say that if the mechanical properties are the same, this, bolt patters, mounting holes, flange type, depth, etc., and the only difference is the opening there should be no issues.
Now, the real point for a narrower pattern would be audible distance, how far away and how many DB, or splay. I have had problems with neither and can project over 100db to better than 75-100 feet outdoors with these boxes. Inside with small to medium sized venues these boxes can be anything from overkill to just the right size. After that I'm running the wrong box. Crowds of 1000 are handled well with the right amps. See the point??
Personally I would leave the 725 as is knowing any increase in performance is going to be marginal at best, or look to another type box if that is your need.
BOSTON STRONG........
Proud Vietnam Veteran
Mike Caldwell
  • Covington, Ohio
« Reply #2 on: January 30, 2011, 09:49:30 AM »
The 2385a would not be a direct swap in the SRX 725. The 725 uses the 2451 driver with 1.5 throat and the 2385a horn is a two inch throat. The older SRX series that uses 2445 drivers and 2380 horns it would be a direct swap out and going from the 90 x 40 to a 60 x 40 horn would be a improvement for longer throw and or arrayability.
Page created in 0.065 seconds with 23 queries.
