Author Topic: analog way vs. macs  (Read 5076 times)
Cliff Fuller
analog way vs. macs
« on: January 25, 2011, 06:37:09 PM »
I've got an Analog Way Easy Fade that I'm trying to interface 2 Mac laptops with. The device recognizes that there are 2 computers on inputs 5 and 6 but will only pass input 5 reliably. I've tried different resolutions as well as different combinations of computer/inputs (including input 7) but the best I get is an output from the 2nd laptop that appears to have lost sync or something. If 2 Windows boxes are used everything seems to work perfectly.
Any ideas? Thanks .....
Brad Weber
  • Marietta, GA
Re: analog way vs. macs
« Reply #1 on: January 26, 2011, 07:53:53 AM »
Are the Macs actually VGA out or are they mini DisplayPort with an adapter cable?  The mini Display Port to VGA adapter cables seem to be somewhat problematic.
Cliff Fuller
« Reply #2 on: January 27, 2011, 02:22:40 AM »
Thanks for responding, Brad.
These Macs are older, G4 Powerbooks. Their display outputs are DVI-I (with analog RGB). We have tried both, the Apple DVI to VGA dongles and those manufactured by 3rd parties.
I have read about the issues with the mini Display Port adapters. That headache will be for another day after I upgrade my laptop  ;)
Karl P(eterson)
« Reply #3 on: February 16, 2011, 11:59:55 AM »
I have almost a dozen macs with mini-display ports and use them in a wide variety of different scenarios. So long as you realize that OSX (like Vista/Win7) obeys EDID religiously and keep the appropriate spoofers around you shouldn't have a problem.
I believe that you are probably seeing EDID issues, although I must admit it has been a very long time since I have used G series hardware. Even so, assuming it is running OSX, it should obey the same rules.
That said, Current I have a variety of Macs with outputs encompassing DVI, Mini-DVI, and Mini-Display-Port. All of them need various adapters to get where they are going. We use mostly Analog Way and older TVOne boxes. They all need a spoofers to work properly.
You should make sure you keep both DVI EDID spoofers (Gefen makes the Detective) or VGA EDID spoofers (I keep Kramer VP-200K around) for these types of jobs/troubleshooting
Hope that helps,
Karl P
Cliff Fuller
« Reply #4 on: March 06, 2011, 06:34:11 PM »
Hope that helps,
Karl P
Some other reading that I've done supports your suggestion, Karl. I finally got my hands on a "spoofer" dongle but it didn't seem to resolve the issue. I did find it interesting that the particular adapter I used didn't need it's optional power transformer if I connected it directly to the computer (after the DVI to VGA adapter) but did need it if connected at the other end of the VGA cable before the switcher/scaler.
Thanks for the suggestions, though.
Page created in 0.088 seconds with 22 queries.
