Author Topic: Texture Water Effect  (Read 2788 times)
Steven Leonard
    • Sands Productions
« on: July 22, 2011, 03:25:26 pm »
Hey Guys! Trying to get a textured effect similar to the Martin DC 1 Water Effect. (See photo)
Unfortunately Martin discontinued this product.
Can anyone recommend a similar fixture that can achieve this? I need a couple for an event.
Moving heads are out of the question because of size.
I know there is the ADJ H20 but Id prefer to stay way from ADJ if at all possible.
Preferably DMX controlled which neither the Martin or ADJ are.
Thanks in advance!
Ray Cerwinski
Re: Texture Water Effect
« Reply #1 on: July 22, 2011, 05:21:51 pm »
http://www.rosco.com/us/lightingequipment/x24effects.cfm
DMX controllable and small form factor.
I use the American DJ units exclusively and they have yet to let me down. Lamps are cheap, the fixture is cheap, and the effect is spot on. I also won't cry if one breaks, I can't say the same about the above Rosco unit.
You can also get quite crafty with a Source 4, twinspin, and different combinations of textured glass and crushed dichroics. Nice and bright, multiple lens options.
Ray Cerwinski
Steven Leonard
    • Sands Productions
« Reply #2 on: July 22, 2011, 06:22:24 pm »
Thanks Ray! Do have the LED version? U mentioned lamp so wasnt sure. Thx for the help!
Ray Cerwinski
« Reply #3 on: July 22, 2011, 06:51:49 pm »
I have the H20 250 which uses 250w halogen lamps (MR16 style, an LL-ELC to be exact)
Ray Cerwinski
duane massey
« Reply #4 on: July 23, 2011, 03:12:44 am »
Brand new from ADJ:
http://www.americandj.com/ProductDetails.aspx?Category=&ItemNumber=2057
I've had far fewer failures with ADJ vs either Martin or Chauvet in this range of fixtures.
Duane Massey
Houston, Texas
Brad Majors
« Reply #5 on: August 09, 2011, 02:06:00 pm »
Brand new from ADJ:
That's nice- haven't seen that before. I have some of the older AMDJ halogen H2Os. They seem a little dim at times depending on how much ambient light is around. I like the beam angle option on the new unit. Any idea how these stack up against the old bulb version as far as brightness?
Thanks!
event lighting
« Last Edit: August 09, 2011, 02:09:57 pm by sound and vision »
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #6 on: August 09, 2011, 04:53:27 pm »
That's nice-
Please go to your profile and change the "Name" field to your real full name as required by the posting rules clearly displayed in the header at the top of the section, and in the Site Rules and Suggestions in the Forum Announcements section.
Posting Rules
