Author Topic: Networking  (Read 6818 times)
zohar pajela
Networking
« on: July 15, 2011, 05:10:18 am »
what's up guys,
one quick question, i just want to find to find out how you guys network your vertecs and crown amps.
i was just wondering if we should be getting cisco switches and routers instead of using our home grade hubs and linksys router. would that be to much or is that the way you guys do your network too?
i do have some basic knowledge with cisco's stuff and i feel that it would help us a lot and make the network more stable
thanks,
ZOhar
Robert Weston
  • Power is cheap, reputation is not.
Re: Networking
« Reply #1 on: July 15, 2011, 10:17:09 am »
Home grade stuff should be fine, but probably depends on how important redundancy is for the networking and if you feel that having non-managed switches is ok.  I can't really say yes/no to this.  However, the use of hubs in any network is now considered a huge "no no".
Chris Carpenter
  • Baton Rouge
Re: Networking
« Reply #2 on: July 15, 2011, 03:52:50 pm »
First off, cisco owns linksys. So don't go off and replace all your linksys gear with cisco for brand loyalty.
If you don't have a good bit of experience with managed networking, you may want to stay away from the managed gear. While the increased flexibility is great for computing, it just means more stuff to go wrong if you don't know how to set it up.
You mentioned making the network more stable. What stability problems are you having? If you have no unexpected downtime and the network is fast enough, stick with what you have and spend your money elsewhere.
If you are familiar with managed networking and feel an upgrade would be useful, a couple advantages that you will find in enterprise networking equipment is that it will typically rack mount in your standard racks, and be much more durable.
+1.  Ethernet hubs were a bad idea in 1990, and there are an even worse idea today.
« Last Edit: July 15, 2011, 03:56:21 pm by Chris Carpenter »
  • Old enough to know better
  • Audio Plumber
Re: Networking
« Reply #3 on: July 15, 2011, 06:58:03 pm »
On the other hand, don't confuse Linksys gear with Cisco gear, the 2 are not equivalent.
Jonathan Johnson
Re: Networking
« Reply #4 on: July 16, 2011, 01:00:11 am »
There are three product lines: home, small business, and enterprise. The Cisco name has replaced the Linksys name across all three product lines. The enterprise line that always was Cisco will continue to be called Cisco; what used to be Linksys Business Series is now Cisco Small Business Series, and what used to be Linksys home stuff is now Cisco Home Networking.
And to clarify, a hub and switch essentially serve the same purpose, but switches are smarter and more efficient. They don't make hubs anymore, thank goodness. (Think of a hub as the old party line, where everyone heard everyone else. A switch sets up "private line" routing between each node, so the nodes only get the traffic intended for them.)
In my opinion, the Cisco Home Networking stuff is total crap and nowhere near the quality of the old (+5 years) Linksys home-grade gear. The shape of the Cisco Home routers remind me of a cowpie.
Chris Carpenter
  • Baton Rouge
Re: Networking
« Reply #5 on: July 16, 2011, 03:01:44 am »
Right, the two product lines serve different purposes. I'm just saying there's nothing inherently better about cisco gear. They both do what they were designed for very well, and Zohar should pick the one that fits his needs.
That may be the case, but the old linksys gear was hard to beat. The wrt54g was about as badass as a piece of networking gear got. It's the only reason I haven't yet upgraded to N.
But back on topic. If you could use the features of the enterprise equipment, go for it. If what you have is working, stick with it.
Finally, if you do decide to go managed, give some consideration for ADTRAN equipment. I spent three years at the company writing the control software, and the hardware is very well built (think CS800). Also, built and supported here in Huntsville, AL.
Jonathan Johnson
Re: Networking
« Reply #6 on: July 16, 2011, 12:18:37 pm »
Still have one that's 8 years old; using it right now. Solid as a rock.
I wouldn't have a problem recommending the Cisco Small Business stuff, usually cheaper than enterprise gear and for the OP's application will probably perform very well. I've had bad luck with the lower-end Dell switches; they use a Realtek chipset. I have had a lot of problems with Realtek-based network devices (slow thruput, locking up, high error counts).
That said, I don't know what's inside the Cisco SB stuff... I've never opened one up to see. Maybe it's Realtek, then the egg would be on my face. I sure hope not.
I haven't tried the latest generation of HP ProCurve switches. In the past, I had a lot of problems with port speed/duplex/MDI-X negotiation. Devices that supposedly linked at 100Mbps full duplex saw dialup speeds; locking the port to 10Mbps (one tenth the speed) would make it perform as expected. Plug the device into any other brand of switch and it would work just fine no matter the speed setting.
  • Audio Plumber
Re: Networking
« Reply #7 on: July 16, 2011, 12:29:48 pm »
Yeah, they keep working, in their way, but I have both a WRT54g, and a WAP11, and neither one of them has as good RF performance as my Apple Airport or Airport express. I only keep the 2 Linksys access points around for those occasions where I need to attach an external high gain antenna. Even with internal fully enclosed antennas the 2 Apple access points have much better range than the Linksys, and almost never need to be rebooted.
If I was relying on a wireless access point to actually run a show, where a failure could cost me a client, the investment in an enterprise grade access point would be worth the money. Linksys ain't that.
Bob Leonard
  • Boston, MA USA
Re: Networking
« Reply #8 on: July 17, 2011, 10:41:44 am »
Cisco makes a series of switches for just about every use, and to fit every budget. Vertec was a part of the original post so my assumption is that this equipment will be used for performances where reliability should be the number one consideration. That being the case I would not be looking at low cost home use hardware.
I would suggest that anyone with serious dependencies limit their search to either the Cisco Catalyst compact series, HP V series, or even Dell as a starting point. Either series can provide reliable entry level hardware and services. HP switches can be purchased as either managed or unmanaged. WAPs fall into the same catagory but switches were the original topic. However, the same rule applies.
Also be aware that a switch does not have to be segmented into subnets and that all ports will be active out of the box providing the same functionality as a hub. This is true of almost all switches with the exception of enterprise class products.
http://www.cisco.com/en/US/products/ps11527/Products_Sub_Category_Home.html
http://h17007.www1.hp.com/us/en/products/switches/index.aspx
You might also be interested in knowing that Dell has a good series of switches available. These are very common in large data centers and they offer an additional benefit. The benefit is that you can purchase an extended warranty with optional 4 hour support. should the switch fail, not power on, etc. you'll have a new one within 4 hours, is the Boston area probably less than 2 hours. These are mostly re-branded Cisco at a much better price. Any of the power connect series will fill the bill.
http://www.dell.com/us/enterprise/p/switch-powerconnect
I have seen very, very few switch failures within the class of hardware I mention above. Many switch failures with home class junk.
Good luck with your search.
BOSTON STRONG........
Proud Vietnam Veteran
Bob Charest
  • Lab Lounge
  • Westbrook ME, USA
    • Bob Charest Band
Re: Networking
« Reply #9 on: July 17, 2011, 12:06:46 pm »
Hi Bob,
In trying to get a rack-mountable wireless router with an external antenna I came across the CISCO1811-K9. The used unit I was looking at has since been sold, but I'd like to know if you had any experience with that model.
Thanks,
Bob Charest
Re: Networking
Page created in 0.05 seconds with 24 queries.
