Author Topic: Source for 200' CAT-5e snake and reel  (Read 6638 times)
John Moore
  • "learning the hard way sucks donkey kong"
    • Trinity Productions
« on: July 11, 2011, 05:26:53 pm »
Need to find a source for the above...looked via search but did not turn up much....we have a 100' from Allen Heath, but don't want to put two together with a connector in the middle, since some events we do are on grass.
http://www.trinityprosound.com 209-832-8023
DEALER:Dealer for Yorkville, EV, QSC, RCF, Danley Sound Labs, VTC, Allen & Heath, Ashly, Denon,  Audix, One Systems, Beyerdynamic, Presonus, K&M, Ultimate,  Trusst, Road Ready, Gator, Radial Engineering, Turbosound, dB Technologies, RCF, American Audio,  Rapco, CBI Cables, ADJ, Chauvet, Blizzard, Furman, Shure, Tascam, Elite Screens,  BenQ, Midas, Digico,  and many many more...
Tracy Garner
Re: Source for 200' CAT-5e snake and reel
« Reply #1 on: July 11, 2011, 05:37:30 pm »
Cables To Go has that length but I didn't see the reel as part of it - just the cable.
Jonathan Kok
  • Toronto
« Reply #2 on: July 11, 2011, 05:54:37 pm »
Both Gepco and Belden make DuraCAT cables (rubberized jacket), available in up to four channels (4x C5e).  As for pre-finished, Roland has one (though not as durable, and not sure of the manufacturer), Rapco has a couple of types (again, not sure of the cable manufacturer), Digiflex uses Belden I believe.
Roll your own reel. Canare's are nice, but costly.  Rapco's are cheaper.  With a Canare reel, you can install a Neutrik EtherCON panel-mount on it so that you don't need to unreel the whole thing every time.  Wind out as much as you need, then patch into the jack on the reel.  I don't know that you can order it from Canare, pre-made with the DuraCAT, but it'd be worth looking into.
Craig Leerman
  • Global Moderator
  • Do Not Read This!
« Reply #3 on: July 11, 2011, 10:04:35 pm »
Markertek.com has a lot of different reels with Cat5.
http://www.markertek.com/Cable-Management-Protection/Cable-Reels/TecNec-Cables-Connectors/MKR-12.xhtml?MKR-12
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
Darren Scaresbrook
  • Adelaide, South Australia
    • Concert Systems Australia
« Reply #4 on: July 11, 2011, 11:31:03 pm »
Hi John,
I'm using Ramcat from Klotz. I generally use 2 x 250ft (ethernet and ethersound) runs, and even if fully extended they are quick and easy to roll by hand. About the same diameter as a mic cable but a lot tougher outer jacket. The ethercons fit and clamp really nicely. If you don't use a reel, they take up next to no space in the leads packer too  :D
Darren
Mike Pyle
  • Santa Rosa, CA
« Reply #5 on: July 12, 2011, 12:01:58 am »
Markertek sells the Hannay AVC-16-10-11-DE reel. It will easily hold 250' of solid core Duracat from Rapco, and allows you to spool a leader on the second reel segment. You can get the cable with Ethercons at each end.
Iain.Macdonald
« Reply #6 on: July 12, 2011, 01:36:26 pm »
John,
Neutrik etherflex.
Iain.
Mark Allen
« Reply #7 on: July 13, 2011, 09:49:10 am »
A single piece of cat 5 didnt do it for us with digital consoles and snakes, we always want a back up and a few XLR lines for com and other analog sends/returns and Whilrwind has a nice option
http://whirlwindusa.com/catalog/snakes-splitters-and-multiwiring-systems/snakes/medusa-cat-6
Ray Soly
« Reply #8 on: July 13, 2011, 10:24:17 am »
we got this http://www.tmb.com/Pdf/ProPlexCAT5e-LTR-web.pdf   from proplex for our ILive system, (90 meters/327ft) they also have a twin cable with redundant CAT5e PCCAT5EPX2 Dual CAT5e SFTP
Ray
Doug Hammel
« Reply #9 on: July 13, 2011, 08:03:36 pm »
+1 for Whirlwind.
Doug Hammel
dougcvaudio@gmail.com
