Author Topic: Confidence Monitor system  (Read 7439 times)
Steven Kramer
« on: June 16, 2011, 11:09:28 AM »
Looking to hear what everyone is using for a confidence monitor system as we are looking to purchase one for our facility. We would like to be able to conceal the stand as best as possible. I have only seen the Da-Lite Stand that has a skirt in the back - www.dalite.com/products/product.php?cID=59&pID=444 Has anyone used a stand that is totally concealed from the audience?
Is there a solution to not only include their presentation (PowerPoint) on the monitor but a time reference as well like a clock, countdown timer, and/or the green yellow red indicator?
Thanks
Kellen Tyburski
    • Kellen Tyburski | Audio Engineering
Re: Confidence Monitor system
« Reply #1 on: June 17, 2011, 08:12:56 PM »
Thanks
What type of environment are you using this in?
In a hotel environment, I am not a fan of that particular stand, or others like it (its just a taste thing i think, because i know some guys who love it). I have found that you can get the tilt you need from a guitar stand, and no drape is needed.... little more of a slick look.. as for the clock, a limitimer with a (http://www.knightpro.net/Product%20Images/Inventory%20Pics/DSan%20Large%20Display.jpg)  large clock works pretty well.
KT
Craig Leerman
  • Global Moderator
  • Do Not Read This!
« Reply #2 on: July 11, 2011, 10:26:56 PM »
For large flat screens I use an amplifier stand, the kind used to tilt back guitar amps onstage. Then I just gaff tape some drape around the monitor and it hides the stand and any coiled cables underneath.
For smaller screens I use guitar stands, and drape.
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
Justin Dodd
« Reply #3 on: July 24, 2011, 01:51:30 AM »
I either use custom wooden stands that are at a set tilt back angle or lay the screen back using a front fill speaker to prop it up (done right it is very discreet).
Most event planners I work with would freak at the sight of that Dalite contraption...
Justin
Collin Donohue
« Reply #4 on: July 27, 2011, 06:38:03 PM »
Before anyone was actually marketing one, we had a bunch custom-built by our local metalworking shop that could fit up to 55" screens and was integrated with Chief brackets (all of our other stands were Chief).  We typically just put a black drape over the bracket portion (leaving some open space in the back for air circulation).
For a couple shows, we have made full surrounds out of black foam-core.  The back would be a rectangle matching the height of the screen and the sides would be at a matching angle to the screen.  Looked very nice and was a quick and cheap solution for the show.  No picture of that, unfortunately!
Page created in 0.055 seconds with 23 queries.
