Author Topic: HME Pro 850 Wireless Com-Howling Issues  (Read 5945 times)
Loren Aguey
  • New York City
« on: May 12, 2011, 11:40:29 am »
This unit is among the nicer wireless com units I've used. Highly configurable and sound quality is very clear, and properly configured the range is very good.
I'm on a show right now and every once in a while someone on wireless will go to talk and there's a high pitched howling, almost oscillating sound that is transmitted through all the wireless and RTS in the chain. It doesn't quite sound like normal feedback its more electronic sounding. Its not the normal sound of RF interference I've heard in the past.
This is one of the smaller rooms on the MS campus and we've had normal RF interference issues in the past with our other HME system UHF system 800, which is fixed frequencies in the 400 range.
This is a rental unit so I'm going to call them on my next break just wondering if anyone has any thoughts on this.
Thanks.
Henry Cohen
  • Westchester Co., NY, USA
Re: HME Pro 850 Wireless Com-Howling Issues
« Reply #1 on: May 12, 2011, 10:31:26 pm »
Is it only one or two beltpacks causing the problem or is it random beltpacks? Where is the offending beltpack when the noise occurs?
Are the beltpacks set to PTT or PTTx?
Henry Cohen
  • Old enough to know better
  • Audio Plumber
« Reply #2 on: May 12, 2011, 11:03:07 pm »
Also, what kind of headsets are used with the HME packs? It might be mechanical, or electrical feedback in the headset.
Loren Aguey
  • New York City
« Reply #3 on: May 13, 2011, 08:20:26 pm »
Well I though it was one of the beltpacks but after it was swapped it happened again a couple more times throughout the day. It always happened within 10-15 ft of the base station.
And I'm not familiar with the setting PTTx. After a quick check in the manual I didn't see anything about it. This was something I didn't have to configure but there was no function to lock the push to talk button if that's by what you're asking.
I'm not sure the exact model but they were lightweight headsets similar to these.
http://www.rftechnostore.com/php/proddetail.php?prod=RF6
It did kind of sound like that. Any way to determine in the future if that's what it was? We don't own these it was a rental but I imagine I'll come across them again.
Henry Cohen
« Reply #4 on: May 13, 2011, 09:47:56 pm »
Sounds like the beltpacks are in high power (100mW) and  saturates the front end of the base RX when too close. The RF overload of the demodulator caused enough bleed resulting in the squelch opening. This was one of the issues with the first generation of Pro850, since resolved. Set the beltpacks to AUTO (if not already) and reposition the antennas [higher] so it's not likely a pack will get close enough to trigger the problem.
Quote
PTT = Push To Talk, meaning the pack's transmitter is always on, the talk button merely opens the audio circuit.
PTTx = Push To Transmit [and talk]. Transmitter is off until the button is pushed.
Quote
Interesting you would point to a headset supplier in a different industry, as opposed to referencing an example from a pro audio supplier or manufacturer.
Henry Cohen
Loren Aguey
  • New York City
« Reply #5 on: May 14, 2011, 10:55:15 pm »
Quote
Quote
Thanks for the help Henry I'll definitely look into those settings next time. For this situation would you recommend PTT or PTTx?
As for the headset I linked, I didn't even notice they were drive through headsets I just googled hme headsets real quick picked those because they looked closest to the ones we rented.
Henry Cohen
« Reply #6 on: May 15, 2011, 07:42:22 pm »
PTTx is recommended for most situations except with those users who are too impatient to wait the split second for the transmitter to fully key up, or who really do need to talk instantly (life-safety).
Henry Cohen
  • Audio Plumber
Re: PTTx
« Reply #7 on: May 15, 2011, 08:01:51 pm »
If I am wrong here maybe Henry will correct me, but I think there are two advantages to PTTx vs PTT. The first and most obvious is the increased battery life in the portable packs when they are not transmitting all the time. The second is that it creates a binary condition for the channel squelch. Rather than have a slowly weakening signal try to hold the squelch open as a user goes out of range, that channel is already fully squelched. This avoids some of the "swishing" interference we have all experienced. If the user tries to talk from out of range, either it will not work, or there may be some of the weak signal artifacts, but they will only happen while hey are trying to transmit, not the whole time the are borderline out of range.
Henry Cohen
Re: PTTx
« Reply #8 on: May 16, 2011, 12:09:09 pm »
Mac is correct on both counts. And of course the less active transmitters running around, the quieter the RF noise floor, which in turn means greater range and less chance of RF saturation of various RF gain stages.
BTW, the corporate I'm doing now is a good example. Out of 20 BTR beltpacks, only two are on constant transmit (PTTx); one is for the SM who has to make a some automation (safety) calls and the other is for the AD who's simply not able to 'push, pause, talk'.
Henry Cohen
Loren Aguey
  • New York City
Re: PTTx
« Reply #9 on: May 16, 2011, 06:38:39 pm »
Thats great info thanks guys. I never considered the battery life aspect of that. I wonder if that was why when we had to rent the Tempest900 they absolutely devoured the batteries in very little time. Either that or maybe some high power tx boost setting or something I didn't have time to troubleshoot it.
Anyway, now I know a couple more things to look out for. Thanks again.
Re: PTTx
Page created in 0.032 seconds with 22 queries.
