Hey Tom -
Are you using the standard control panels available in SA, or are you doing a custom control panel? The one I mentioned above was done with a custom panel setup, after flailing about for a few hours. Like you, I couldn't get the XTi and IT standard panels to operate simultaneously, presumably due to the differing protocols.
It'd suit me just fine if Harman/Crown updated Band Manager to include the IT line. It's (Band Manager) all I need for portable use.
gp
If I create a custom control panel and add amplifiers to a graph, I can only add xti or itech.
I can’t take something like this;
And add the Itech 4k to control the 728s from this panel But I get 8 bands of mid and high amps for SRX725s
It’s not an issue, since I just make another itech only control panel.
I know, …I should have all itechs and not have the issue.
But those aren’t in the cards anytime too soon.
I use an Ethernet-USB bridge to talk to the XTI.
The software emulates the four USB ports on the laptop.
I have 2 xti4000 on wedges + and XTI 6k (mids) and an XTI 1k (tops).
SA talks through a VID for USB to XTI amps.
SA uses native TCP/IP for Itechs.
I believe a single panel is constrained to a single protocol.
tom
Well, there was an attachment but the forum wont let me do it.
