Author Topic: Unclogging Look Unique Hazer  (Read 5751 times)
Brian Gowing
    • Gowing Associates
« on: January 14, 2011, 01:47:42 PM »
I acquired a used Look Unique (not Unique 2) hazer. Everything works on it except it's clogged and I've been unsuccessful at getting it unclogged. I've tried to use vinegar to run through it but the air pump hose keeps blowing off the Y fitting. A new heater core costs about $285 so I'd like to find a cheaper solution. Anyone got any ideas of what I can try to unclog it?
Thanks,
Brian
Brian Gowing
Technical Consultant
Christian & Missionary Alliance
Gowing Associates
Matt Jordan
  • "Man, this is fun!"............."Still!"
    • Maxxsounds Audio co.
Re: Unclogging Look Unique Hazer
« Reply #1 on: January 16, 2011, 08:36:14 PM »
Hi Brian,
  I have been succsessful using a 75% to 25% vinegar to distilled water mix. Just let it sit for about a week. About a 30% chance of it coming back alive. The key is to clean it according to the manufacturer's recomendations before it gets that bad.
 Hope that helps.
Matt Jordan
     Maxxsounds Audio co. Boise, ID
       www.maxxsoundsaudio.com
Give the people what they want, they will give you what you want.
Brian Gowing
    • Gowing Associates
« Reply #2 on: January 17, 2011, 07:59:58 AM »
Thanks Matt. I'll try that and hopefully that will take care of it. I suspect that the previous owner didn't follow the directions on usage and that it got clogged and they kept trying to use.
Brian Gowing
Gowing Associates
Gus Housen
« Reply #3 on: February 25, 2011, 09:17:14 PM »
i was rooting around a hobby shop one day and found some very small diameter metal rod, i had a old Fogger I inherited that didnt work. the small rod worked.
Page created in 0.023 seconds with 23 queries.
