Author Topic: Compressors - In's and Out's, When's and Why's?  (Read 7295 times)
Kevin "DJ Wave" Boreing
« on: April 26, 2011, 09:20:47 am »
I've been mixing live sound and DJ environments for nearly 10 years now, running everything from simple small channel mixers to larger and more complex digital systems. One thing that has personally always been a plague on me is compressors.
I understand how and why they work (for the most part), but it just seems that every time I go to assign either a single channel compressor, or the overall compressor, I start loosing what I feel is the solid sound and dynamics in the mix. Especially in church settings where the dynamics in a song can go from soft to powerful in short phrasing, I find that relying on the compressors simply takes away from the dynamics of the performance.
Yes it makes it easier to control the peaks especially in the mix, but I usually find myself relying on the individual channel limiters (this being on the i-Live T112) to compress the peaks but not the full compressors to allow a dynamic range, either through the musicians themselves or through live mixing.
I guess my main question is, am I mixing incorrectly by taking this approach? Should I be relying on the full compressor to give the sound an overall "CD recorded" sound like you'd get on most modern recorded music and keep it all the same level? Is my understanding of compression lacking so that I may be looking at this all the wrong way?
Robert Weston
  • Power is cheap, reputation is not.
Re: Compressors - In's and Out's, When's and Why's?
« Reply #1 on: April 26, 2011, 10:04:08 am »
Sounds like maybe the compressor is incorrectly used and/or it's setup incorrectly.  If you want the wide dynamics (let's say the vocals), make sure the threshold of the compressor is set to -0- to start.  Then set the ratio of the compression to something like 4:1.  If the threshold is set below -0-, the compressor will kick in early.  Setting it to -0- or above will allow the dynamics (soft passages) to come through before the compressor starts.   I'm not familiar with your board or the type of compressor you may use, but (for vocals) make sure something like "RMS" is selected and/or something like "soft-knee".
I use a compressor on my vocal subgroup - analog board.  It's setup similar to what I described above.
It's a balancing act....
g'bye, Dick Rees
  • Duluth
« Reply #2 on: April 26, 2011, 10:25:43 am »
Considering that it is the function of a compressor to reduce the dynamic range of a signal, I don't know why you should be surprised.
« Reply #3 on: April 26, 2011, 10:30:50 am »
It's not surprising, it just makes me not want to use much if any compression over a basic limiter function. But if I am understanding or using the compressor incorrectly, then it would be good to know that, as my fundamental understanding of a compressor is to cut dynamics to increase overall volume levels/ cut harshness.
If a board features both separate limiters and expanders, why would you also want to employ a full compressor unless you are trying to go for that "all one level" radio sound.
g'bye, Dick Rees
  • Duluth
« Reply #4 on: April 26, 2011, 10:33:54 am »
So don't use it.  Nobody's putting a gun to your head to make you use it.
« Reply #5 on: April 26, 2011, 10:41:28 am »
Sweet, awesome to know inquiries in fundamental techniques of sound mixing and technology are met with such idiotic and rude responses. Bodes well for your professional reputation man, I'll be sure to disregard anything further from you....
Rafi Singer
    • Singer Production Company
« Reply #6 on: April 26, 2011, 11:42:11 am »
Compression is a tool, just like any other processor. There are times to use it and times to not. It seems like you've found a mode of working that is appropriate to your environment and it is one with little or no compression and you know what? That's perfectly fine. In a highly dynamic environment like you've described it seems like a situation where compression would be best applied to control peaks, but you've found a way around that.
A few ways I end up using compression:
- To thicken up a bass that has a ton of attack and not much body
- (In high stage volume situations) to help get the vocals on top of the mix
- Over a subgroup to achieve a bit more bod
  • Old enough to know better
  • Audio Plumber
« Reply #7 on: April 26, 2011, 12:03:56 pm »
That was the most succinct answer you got. A compressor's only purpose is to reduce the dynamic range. if that sucks the life out of the sound, don't do it. Compressors are vastly overused today because of the ready availability on digital consoles, you don't have to follow the crowd.
Any process you use, whether it is eq, dynamics control, effects, or anything else, should only be used if it gets you closer to the sound you are trying to get. They should not be used as some universal panacea.
Greg_Cameron
    • Cameron Pro Audio
« Reply #8 on: April 26, 2011, 01:09:03 pm »
I tend to lean in this direction myself. I use a good quality compressor on a vocal subgroup and have it set for very fast attack/release & higher ratio (~10:1) with a relatively high threshold to keep loud vocals from getting out of control without affecting the more average level. As long as your rig has the headroom to go this route, it should work fine. If I'm using a rig that doesn't have that headroom, I might be more inclined to run with a lower threshold, lower ratio, and slower attack/release speeds.
Quote
But if I am understanding or using the compressor incorrectly, then it would be good to know that, as my fundamental understanding of a compressor is to cut dynamics to increase overall volume levels/ cut harshness. If a board features both separate limiters and expanders, why would you also want to employ a full compressor unless you are trying to go for that "all one level" radio sound.
This gets into issues of taste and effect. I tend to use compression pretty sparingly on other things like bass, guitars, and drums. Just enough to keep things under control a bit. Things that tend to get more compression would be really dynamic instruments like horns and certain string instruments that can go from soft to rip your head off loud very quickly. I'll usually throw one on keys as well, especially with acts I'm not familiar with as those levels can jump all over the place & I hate surprises. Usually the audience does too. Nothing wrong with precautionary measures.
Greg
Cameron Pro Audio
Mike Harper
« Reply #9 on: April 27, 2011, 10:34:05 am »
I'm with you I prefer the dynamics, gives the music/vocals more life.  We run compression on each vocal channel and on a couple acoustic guitar channels.  I like to use the compression to help smooth things out a little and still keep most of the dynamics.  mot of my vocal channels have compression ratios set at about 2.5 and thresholds at -6db.  However i have a couple female vocalist that have amazing range, they can distort some lower end dynamic and condenser mics (SM58, EV N/D267 and EV PL84) with no problem with out the preamp on the console clipping, but they also go so soft at times that you can't even hear them.  We've worked with them on mic handling and things but also run compression on them.  Their compressors are set at ratio of 3.5 and a threshold of about -10, I also give them a little make up gain from the compressor for their soft moments to keep preamp gain low to keep from clipping it.  these setting work well for us, keeps good dynamics and also keeps things under control.
We are running an A&H GL3800 with DBX 1046 compressors.
Tech Director                        Tech
Calvary Life Church                Output Unlimited
www.gocalvarylife.com           www.outputunlimited.com
Page created in 0.045 seconds with 22 queries.
