Author Topic: What wire to use?  (Read 6357 times)
David Sharp
What wire to use?
« on: December 19, 2010, 09:35:46 am »
Here's my setup:
Mackie SR aux outs
Through roughly 100' of conduit (stage snake in same conduit)
Through Alesis MEQ230's
Into Behringer HA4600 headphone amp (in ears for drummer, bassist, & lead guitar)
And my question:
Shielded or Un-shielded cable through the conduit?
Re: What wire to use?
« Reply #1 on: December 19, 2010, 12:28:53 pm »
David Sharp wrote on Sun, 19 December 2010 09:35
Here's my setup:
Mackie SR aux outs
And my question:
Use twisted pair shielded wire.  24ga is fine.  Be sure to wire it up balanced.
West Pen 291 is a good choice.
dB Audio & Video Inc.
Andy Peters
    • http://www.latke.net/
« Reply #2 on: December 19, 2010, 09:12:15 pm »
David Sharp wrote on Sun, 19 December 2010 07:35
Here's my setup:
Mackie SR aux outs
And my question:
The MEQ230 is unbalanced -- and piece of shit -- so unless you can insert it on the mix outs, get rid of it. besides, you probably don't need it if you're driving headphones.
Everyone gets the same mix? yuck.
-a
"Any sufficiently advanced incompetence is indistinguishable from malice."
David Sharp
« Reply #3 on: December 20, 2010, 07:35:55 am »
The MEQ230 is a fine EQ. It might be unbalanced but it still works you just have to be conscience of where you place it in your signal chain. Hence why it is going onstage next to the headphone amps so I can run a balanced line from the board over the longer distance.
There are 4 seperate mixes and since they are going through Behringer Headphone amps I'm sure anyone would appreciate a 30 band EQ.
Brad Weber
« Reply #4 on: December 20, 2010, 09:36:00 am »
David Sharp wrote on Mon, 20 December 2010 07:35
Aren't both the inputs and outputs unbalanced on the M-EQ230?  Are you putting input transformers at the EQ inputs?  If the inputs are unbalanced then the run to them would be unbalanced despite the console output being balanced.
So who is going to be adjusting the EQ?  At least it's for in-ears and not for floor monitors.
Brad Weber
muse Audio Video
www.museav.com
Andy Peters
« Reply #5 on: December 20, 2010, 03:24:59 pm »
David Sharp wrote on Mon, 20 December 2010 05:35
No, it is not. It is barely adequate as a wedge with which to adjust monitor-wedge angles.
Quote:
 It might be unbalanced but it still works you just have to be conscience (sic) of where you place it in your signal chain. Hence why it is going onstage next to the headphone amps so I can run a balanced line from the board over the longer distance.
Running a balanced output to an unbalanced input doesn't buy you anything.
While I'm no fan of Behringer, there's no reason to believe that a simple headphone amplifier will degrade the signal such that it needs to be corrected by an EQ.
-a
Page created in 0.033 seconds with 20 queries.
