Author Topic: Video Editing Workstation  (Read 20235 times)
Kevin Willis
    • http://www.cornerstonemediaservices.com
Re: Video Editing Workstation
« Reply #10 on: May 01, 2010, 06:16:39 PM »
You can use an off-the shelf computer, but you will likely find that it is extremely limiting. First, the integrated video cards are basically worthless when it comes to editing. Second, when you go to render, assuming you are rendering a full service, expect these computers to take several hours. For editing, I always recommend either building and good quality gamer-type pc or buy a multi-processor Intel-based G5 MAC and make sure to add lots of RAM, 8GB minimum. Newegg is an excellent source for ordering pc parts.
The main issue with capturing tape, regardless of the media, is that is real-time, meaning that a two-hour service will take two hours to capture. Focus Enhancements makes some great portable firewire hard drives that capture uncompressed video that can then be transferred to your the editing computer. This is a huge time saver!!! Recording to a DVD recorder uses compression which will degrade the image quality.
I'm not sure if this answers your questions, but I hope it helps.
Kevin Willis
Cornerstone Media Services
www.churchmediatalk.com
Arnold B. Krueger
    • http://www.pcavtech.com
« Reply #11 on: May 05, 2010, 08:08:58 AM »
Kevin Willis wrote on Sat, 01 May 2010 23:16
I'm wondering what kind of video editing software runs that poorly, so it requires major CPU horsepower to even achieve 1:1 rendering times? Is it even trying to use multiple cores?
The same applies to video cards. What is it about your editing style that seriously taxes a modern on-board video interface?
Kevin Willis
« Reply #12 on: May 06, 2010, 08:55:55 AM »
Arnold B. Krueger wrote on Wed, 05 May 2010 08:08
Most real editing software, specifically Vegas or Premier, will take advantage of mulit-core or multiple processors, which greatly reduces rendering time.
As far as the video card, you need all the video ram you can get to be able to preview in as high resolution as possible, especially when color-correcting.
Kevin Willis
Arnold B. Krueger
« Reply #13 on: May 07, 2010, 10:37:41 AM »
Kevin Willis wrote on Thu, 06 May 2010 13:55
As far as the video card goes, you need all the video ram you can get to be able to preview in as high resolution as possible, especially when color-correcting.
I don't have any PCs with on-board video on hand that *won't* run 2 1920 x 1200 displays at their maximum resolutions.
1920 x 1200 seems to be the point where further increases in display resolution have questionable practical benefits, and costs ramp up dramatically faster.
AFAIK memory for modern display adaptors, whether on-board or PCI-E have been sizing their RAM allocations to support complex 3D rendering processes at ultra-high refresh rates, as opposed to just being frame buffers.
For example, the frame buffer for a 2D 1920 x 1200 display supports about 2 megapixels, so running 32 bit color would take about 8 megabutes of RAM for each frame buffer. If you double that so that there is 16 bit color and intensity per pixel, there is still ony 16 megabytes per frame buffer.
Modern high performance graphics cards for gaming currently run 512-1024 megabytes, supporting my contention that their RAM was not sized to support high resolution displays.
Karl P(eterson)
« Reply #14 on: July 02, 2010, 03:08:34 PM »
Not to stir the pot more than it needs, but there are needs for more advanced machines in video editing.
Our current spec for a new editing station (Windows or Mac) is an Octo-Core 2.6 or 2.9 machine with 12GB mem and enterprise grade disk to get close to 1:1 render times in our DVCPROHD/Prores422 workflow. When we get a complicated timeline it obviously still stretches way beyond 1:1, even on this class of hardware.
This is all using Vegas or FCS.
Even those machines are close to 1:2 times for even a "simple" bounce from HD to high compression h.264 for the web. On the mac side we are using matrox compresshd cards with compressor to get that down to useable times, unfortunately matrox doesn't like vegas yet or they would be standard issue for us.
However you are correct in that any graphics card with access to over 256meg of memory (either onboard or shared from the main system) seems to work just fine for video editing. Unless we start getting crazy with GPU accelerated effects plugins/programs that is....
For a purely DV workflow you are correct however. We can still edit DV quite comfortably on a 6 year old workstation long since retired from our main workflow.
Karl P
Audio Team Leader - CCH
Christy L Manoppo (okky)
« Reply #15 on: July 03, 2010, 04:52:57 PM »
Quote:
--to 1:1 render times -- stretches way beyond 1:1--
What is "render times" ? I'm sorry if I sounded stupid, but I'm little bit confused here.
As Arnold said, we use DVD-R media to record our services, but when we want to store it into the internet for more viewing options, the quality is just dissapointing.
As I follow through this thread, it's obvious that we dont need that much of CPU horsepower for doing simple DV editing tasks.
FYI, here's the flow..
http://img812.imageshack.us/img812/8300/flowo.jpg
for post, we did like this:
from dvd (mpeg2), devode it to AVI, then all the editing goes in AVI, then back to DVD (mpeg2) again.
For now, I think some of the culprits for the bad quality of our recordings
1. We need a better mixer/switcher for key-ing. Our text and video goes to the projectors at the same time, this is done in the PC with Easyworship software, which has the "live-video feed with text" feature.
2. Instead of putting it all to DVD, maybe we need a Hard Disk Recorder, so we just need to copy the video files, instead of extracting the video from DVD, thus eliminating the encoding/transcoding process.
Christy L Manoppo
Coordinator for AVL Dept,
Bethany Indonesian Church of GOD,
Philadelphia, PA
Perfect? we can't. Excellent? We can.
Karl P(eterson)
« Reply #16 on: July 03, 2010, 10:17:18 PM »
Okky,
When I say render times, I mean the amount of time it takes for the video editing program, after you've finished editing, to "spit out" the final product in a single video.
Rendering doesn't include when you are pulling the video from your device (copying DVD TS Files to your computer, or importing a stream from your (H)DV cam, that is called ingesting.
Rendering doesn't (normally) include how much time it takes to make the video ready to render, also known as pre-render transcoding (although hopefully if you did your ingest right, you won't have to do this).
Rendering doesn't include how much time it takes to record your finished project to media (either burn to DVD, bounce to tape, etc).
Your switcher doesn't look that terrible honestly, I doubt replacing it would bring up your end quality substantially unless it is truly the weakest link in the chain.
Does the quality on your preview monitor or projector look good? Does the DVD straight off the original recorder look good? The question I am trying to ask is where in your chain does the quality start to look bad?
Where the quality starts to diminish is where we need to look for the problem.
This may be in the camera itself, or it may be in one of the transcodes.
Your switcher includes the ability for Luma or Chroma Key, You should try letting the video camera go straight through the switcher and key in your words with Chroma or Luma.
Karl P
Arnold B. Krueger
« Reply #17 on: July 07, 2010, 03:32:28 PM »
Christy L  Manoppo (okky) wrote on Sat, 03 July
What editing software?
When you say AVI which subformat of AVI are you talking about. Isn't your editing software using DV/AVI as your working format?
What mxier? I haven't done a ton of keying with our mixer, but its not elegant, and it seems to do a good job. Our mixer is a Roland Krossfour.
Hard disk video recorders typically compress the video data they store on their hard drives, pretty much the same as DVD recorders. I've used both. IME minimally compressed DVR video does an acceptable job in a NTSC context.
I woulod recommend that you do some troubleshooting, using a custom burned DVD with various samples and trdy ptterns.
Here are some xamples of video test patterns:
http://www.mediacollege.com/video/test-patterns/
Page created in 0.045 seconds with 22 queries.
