Author Topic: Help!!!!  (Read 4272 times)
Byron Walker
Help!!!!
« on: April 19, 2011, 10:51:37 am »
Please Help.  1st I am completely new at this, so keep it simple please.  Backstory - My church has sound system that was setup at least 12 yrs ago.  The people who were around then are not here now.  People have just been guessing at what they are doing for a while. Now I have to figure it all out.  Problem - It seems all the channels are outputting at max regardless of volume or gain on the individual channel.  This is a real problem when trying to use both the CD player and the Microphones at the same time.
Please Help.
Byron
« Last Edit: April 19, 2011, 11:49:27 am by Byron Walker »
Matthias Heitzer
Re: Help!!!!
« Reply #1 on: April 19, 2011, 12:28:11 pm »
It's hard to guess what the problem is when we have no further details.
An easy way to explain us your setup would be some pictures, from the surface of the mixer and it's connectors.
Try to find out where the cables from and to the mixer are ending.
Having no Control over a Signal could happen if you plug it into a post-fade insert with balanced TRS connectors or if the console has inserts with Tip=Return.  But a mic signal would be very quiet then.....
Let me say that this is rather uncommon.
Some fader defects can cause similar behaviour, but this is just blind guessing unless we have more details.
Byron Walker
Re: Help!!!!
« Reply #2 on: April 19, 2011, 01:44:37 pm »
the mics are very quiet.  with just the CD player the master volume is just barely up at all and is loud.  with just the mics the master volume has to be about 2/3 of the way.
I will see if i can get pics tonight.
g'bye, Dick Rees
  • Duluth
Re: Help!!!!
« Reply #3 on: April 19, 2011, 02:13:25 pm »
How is the CD player connected into the board?  What is the board?
Basically, everything that is input into the mixer (board) should have some kind of adjustment to achieve the proper signal level.  On the individual channels it would be the channel gain, usually located at the top of each channel strip.  There should also be some way of metering the input "gain" so it can be properly set.  This may differ depending on the quality/sophistication of the unit.
Playback devices may often be routed directly to the mains via a "2-track" pair of RCA inputs and may or may not have an input gain adjustment.
So what you're looking at here is most likely how to get both the mic and playback input levels to be the same.  For us to tell you that we'd need to know what mixing console you are using.
DR
Frank DeWitt
    • LBP DI Box
Re: Help!!!!
« Reply #4 on: April 19, 2011, 03:08:31 pm »
More information would be a big help but let,s look at some general stuff.
Microphones should plug into your board in jacks labeled something like Mic or Microphone.  CD player should plug into a jack labeled "Line")
There are a number of volume controls on most mixers.  At the top of the mixer there should be one or two controls labeled gain. one may be mic gain and one Line gain, or there may be just one control.
Then there is the main control for that channel (usually a fader or a knob closest to you.  Next is the main fader.
Also if you are using a boom box type of CD player, there will be a volume control on the player it self.
SO......
First turn down the CD player it self,
Next make sure your CD player is not plugged into the microphone jack.
Next turn down the gain control for the CD player near the top of your board.
Frank
Not to Code
Byron Walker
Re: Help!!!!
« Reply #5 on: April 19, 2011, 04:41:05 pm »
Thanks everyone.  The mixer is a Peavey 2002-12 RQ, mikes come into channels 1-8 from the snake, tape deck into channels 9-10 on the line in, CD player on 11-12 on the line in.  The gain has no effect on any channel, the volume fader has no effect on any channel.  the on thing that is controlling anything seems to be the main fader
g'bye, Dick Rees
  • Duluth
Re: Help!!!!
« Reply #6 on: April 19, 2011, 05:00:29 pm »
OK...
Since you have a limited amount of experience here there will be a good bit of guesswork for a while until we reach a balance of information from you and a growing understanding on your part regarding system configuration.  here goes.....
A good guess (given your describing faders not affecting the send levels) would be that the output from the mixer to the system is being taken from a monitor send rather than the mains send.
Your serve........
Aiden Garrett
    • Aiden Garrett
Re: Help!!!!
« Reply #7 on: April 19, 2011, 05:32:55 pm »
Do you have a higher resolution picture? It's very hard to tell how it is setup. A brief look suggests that it's not setup properly - for example, the pan controls (above each channel's fader) are set to hard left. This tends to be avoided.
Aiden
Live Sound Engineer. IT Geek.
Byron Walker
Re: Help!!!!
« Reply #8 on: April 19, 2011, 05:36:52 pm »
Sorry, that is a generic picture not the actual setup.  I will check it out tonight and see if what has been said so far helps and if not try and get some pics.
Thanks again for your help
Byron
Brad Weber
  • Marietta, GA
Re: Help!!!!
« Reply #9 on: April 19, 2011, 05:47:58 pm »
Here's the manual for your mixer, http://www.peavey.com/media/pdf/manuals/80304341.pdf.  Based on that, each channel has an XLR microphone input and a 1/4" TRS balanced line input, so it sounds like you may have them going to the correct inputs.
That is a pretty simple mixer with virtually no switches, button or other selections that would allow the master faders to have an effect on the signal level and not the channel gain controls or faders.  For example, if the house signal was coming from the monitor sends then the individual channel gain controls should still have an effect on the level while the master faders would not.  Since the 'Gain' control is the very first thing all of the 12 inputs hits then something seems seriously wrong if the master volume faders vary the signal but neither the gain knob or fader seem to have an effect for any of the inputs.
A recommendation on a more general level is to see if you can find someone from another local church that has relevant experience and knowedge that could stop by for a little bit.  A few minutes of such time can often be invaluable.
Re: Help!!!!
Page created in 0.073 seconds with 23 queries.
