Author Topic: 01V96 and Digital Snakes?  (Read 1923 times)
Mark Shrimpton
« on: November 19, 2007, 04:46:53 pm »
Hi,
We have a serious renovation project upcoming in our church in the near future, including work on the acoustics and the installation of a new sound system (hopefully the end result will be a lot better than currently).
FOH is not going to change, and we currently have an 01V96 and two a/d converters giving us the maximum in/outs.
What I am pondering is whether to change from analogue to digital snakes.
Now, before you all pounce on me, i have read http://churchsound.prosoundweb.com/index.php/t/14121/c6b8474 a1f8a66aece038c455809fa8b/ on analogue vs digital and found it very interesting.
What I am looking for is whether it is even possible given our current mixer to accomplish this.
We're likely to need 24 input and 6 output channels. We do already have a snake, but with the underfloor heating going in there is unlikely to be an easy way to easily incorporate a 30 channel (excluding any future flexibility) copper snake in the floor. A light digital cable however should be much easier to route from FOH to stage however.
I've looked at the yamaha website and after an hour or two have become overcome with MYxxx cards, cobranet, ethersound, fibre-optics etc etc.
I could just run six fibre cables (3 each way) from A to B and sit three ad/da converters on the stage, but would then have no control of the input gains.
Does anyone know whether it is even possible to control any digital heads remotely using the 01v96 (maybe using cobranet or something else?
Even if so, is it going to be hideously expensive?
Looking forwards to any suggestions
Mark
Gary Creely
    • http://www.steeplesoundavl.com
Re: 01V96 and Digital Snakes?
« Reply #1 on: November 20, 2007, 12:16:01 am »
Mark,
A few questions to help proceed with helpful input-
1. What is the size and path of the current copper, and is it in conduit?
2. Are you sure the heat in the floor will make more difficult run run copper? My first thought is it is the perfect time to put in additional conduit if needed?
3. If you want to go digital I would suggest the Yamaha LS9 as a minimum starting point. With most of the digital snake options you are going to have gain control issues. You likely will need to control the gain on an outboard unit that comes with the snake.
Gary
Gary Creely
STEEPLE SOUND
Page created in 0.04 seconds with 22 queries.
