Author Topic: Using projection as background scenery for upcoming Christmas play  (Read 3883 times)
Jon Bannan
« on: September 10, 2006, 03:56:10 pm »
Hello everyone,
Quick question for you guys and girls,  I had the Program Director just come to me today to start discussing this years Christmas play.  She want's to keep the set small.  So I started thinking about the idea of using rear screen projection as the scenery.  Is anyone doing this?  I haven't really sat down to plot it out, how to put it together.  One of my ideas it 3-4 screens and 3-4 projectors,  and basically putting a set of mpegs of the scenery needed on 3-4 seperate machines hooked directly to the projector.  And then as needed we can make that image live on the appropriate screen.
Any thoughts?  Or if someone is doing this and knows of a better way let me know.
Thanks
Jon
Give me more coffee and no one gets hurt
Brad Weber
Re: Using projection as background scenery for upcoming Christmas play
« Reply #1 on: September 11, 2006, 08:40:40 am »
Using rear screen projection that way is a fairly common concept.  The biggest problem is usually finding the room required.
Short throw lenses can allow the projectors to be about a screen width behind the screen (e.g. about 12' behind a 9'x12' screen) but these lenses also require the projector to be mounted online with the center of the screen both horizontally and vertically, there is usually no lens offset possible.  Going to a lens that allows more flexibility in the projector position typically requires at least 1.5 times the image width or 18' of depth (plus the projector depth) for a 12' wide screen.  The depth required can be reduced with mirror systems but this adds cost and complexity.
Now add that you don't want projectors interfering with one another or light leakage from one screen to another and the power required.  Also consider how the screens and projectors will be physically mounted and the potential of damage to the screens.  You would also need to consider how you control 3 or 4 screens, unless you have an exceptionally high contrast projector and screen you would want to mute or even better gate the projector when there is no image to be shown and then unmute it when an image is desired so some remote control is probably required.
Also remember that with rear projection you might be pretty brightly backlighting your characters and can even cause shadows with them, so more front, side and key lighting might be required to overcome the light from the projectors.  At the same time, although rear projection is much less susceptible to ambient light, you'd still like to keep the light on the screens to a minimum.  These lighting issues are why you often see screens used for backdrops set back some distance from the actors.
Not trying to discourage you, just noting some considerations that often limit whether this concept can be effectively implemented.  In many cases, the space available simply doesn't permit this approach to work very well.
Brad Weber
muse Audio Video
www.museav.com
Jon Bannan
« Reply #2 on: September 11, 2006, 10:31:48 am »
Hey Brad, Thanks!  Luckily I extremely familiar with the distances necessary for rear projection as I do A/V system design, Crestron programming and project management for The College of New Jersey.
I didn't think about the possibility of shadows being created.  Good point.  I have the depth without any problem.  The depth of my stage is about 41 ft deep.  My current thought was to use 3 Epson 830's which are 3000 lumens.  And I can drop them to 2200 lumens in low mode.  The play will be at night and we have decent control of the ambient light on stage.
The screens will be used to form the set so that when the Christmas tree is out in front, you see a living room scene with functional fireplace, etc.
This was the response and advice that I was looking for.  Thanks!!!
Jon
Page created in 0.044 seconds with 21 queries.
