Author Topic: RS232 <-> LAN  (Read 1075 times)
Andrew Broughton
    • Check Check One Two
RS232 <-> LAN
« on: May 28, 2024, 02:25:02 PM »
I have a device that communicates via RS232. There's an app on my computer that can control this device, and while I can very easily use a USB to RS232 dongle, what I'd prefer is to have an RS232 to Ethernet dongle so I can control this from a greater distance and also wirelessly. I have seen RS232 to Ethernet adapters like this: https://www.pusr.com/products/1-port-rs232-to-ethernet-converters-usr-tcp232-302.html and I assume they can "appear" as an RS232 device to the Windows control application?
Anyone done this with some success?
-Andy
TJ (Tom) Cornish
  • St. Paul, MN
Re: RS232 <-> LAN
« Reply #1 on: May 28, 2024, 02:52:20 PM »
I had luck with one of these for an IT application (security system controller running on a virtual server). Reasonable price and support; worked well with Windows Server 2016 I think (its been a while).
Andrew Broughton
Re: RS232 <-> LAN
« Reply #2 on: May 28, 2024, 03:03:10 PM »
Woah. Starting at $576! Good though to get some validation that these sort of devices work as expected.
With the cheaper ones (like the one I linked which is around US$40 or so) I'll have to buy somewhere that I can return it easily for a refund if it doesn't work...
-Andy
Scott Helmke
Re: RS232 <-> LAN
« Reply #3 on: May 28, 2024, 04:30:50 PM »
You might search for "remote RS232", lots of little devices do that kind of thing.
I have a Moxa Nport which used to get used a lot, not so much these days so I don't know if the software is still compatible.
Keith Finch
Re: RS232 <-> LAN
« Reply #4 on: May 28, 2024, 08:39:12 PM »
Digi makes devices that work great https://www.digi.com/products/browse/rs-232
I have used the Moxa and Digi boxes years ago to control XTA, BSS, Shure devices many times.
Adam Kane
  • Battle Creek, MI
Re: RS232 <-> LAN
« Reply #5 on: May 29, 2024, 09:50:42 AM »
I use Global Cache' IP2SL frequently. They have a POE and WIFI version. Basically send the command strings to its IP address on port 4999.
Andrew Broughton
Re: RS232 <-> LAN
« Reply #6 on: May 29, 2024, 10:03:40 AM »
Quite spendy as well. I'll probably opt for a device that costs 1/10th of that, seeing as it's not mission-critical.
-Andy
Dan Richardson
  • southern Vermont
    • NotTooLoud
Re: RS232 <-> LAN
« Reply #7 on: May 29, 2024, 11:49:25 AM »
That's the guy. I use these to operate serial port control ptz cameras over ethernet. Been flawless for several years. $30 each.
https://www.amazon.com/gp/product/B01GPGPEBM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The best sound system is no sound system. Everything else is compromise.
doug johnson2
Re: RS232 <-> LAN
« Reply #8 on: May 29, 2024, 03:53:01 PM »
There are Rs-232 to ethernet converters, mostly used for industrial machine control.  I used to have some Digi units both rj-45 and wireless that I used back when I was still using the original drive racks. There are still current products/drivers available.
Craig Hauber
Re: RS232 <-> LAN
« Reply #9 on: May 29, 2024, 11:14:06 PM »
Moxa nPort
used them for years.  My oldest is from 2004 and it still works fine
Also known as "device servers" and as someone else pointed out, are a mainstay of industrial automation.
https://www.moxa.com/en/products/industrial-edge-connectivity/serial-device-servers/general-device-servers/nport-5100-series
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Re: RS232 <-> LAN
Page created in 0.032 seconds with 23 queries.
