Author Topic: Locking mic stands  (Read 863 times)
Magnus Högkvist
Locking mic stands
« on: May 10, 2024, 12:29:01 PM »
Does anyone have a good idea for locking the height on a mic stand and stopping it from rotating?
For an example I have drum kits with over head stands used for a 10 month season show. They need to be readjusted once in awhile.
I'm using tape to keep them from moving to much.
The drums are on moving stages so there's some vibrations in play.
Chris Hindle
Re: Locking mic stands
« Reply #1 on: May 10, 2024, 12:57:36 PM »
I use mostly K&M booms stands. Yearly maintenance is cleaning all the clutches with rubbing alcohol.
Chris.
Tim Padrick
  • Indianapolis
    • T.P. Audio
« Reply #2 on: May 12, 2024, 06:48:24 PM »
Oil all threads and thrust surfaces and you can get things tighter with less effort.
Rick Earl
« Reply #3 on: May 13, 2024, 06:40:09 PM »
Or spend a ton of money on Latch Lake Stands and Booms
Jonathan Johnson
« Reply #4 on: May 15, 2024, 01:04:02 PM »
A hose clamp on the shaft above the clutch will lock the height, but not keep it from turning.
Brian Jojade
« Reply #5 on: May 15, 2024, 03:03:38 PM »
Good quality stands usually hold position much better than cheaper alternatives, especially if kept in good order.
A bit of gaff tape will add significantly to the stability, but make sure you don't leave any residue on the stand as that will gum up the clutch mechanism and make things worse over time.
Brian Jojade
Dave Garoutte
  • San Rafael, CA
« Reply #6 on: May 15, 2024, 10:32:32 PM »
I've made a couple of prototype self-tightening mic stand heads, with a conical clutch.  As they droop, they get tighter.  You raise them to loosen them.  Too weird for normal use, but great for overheads. Is there any interest?
Frank Koenig
  • Palo Alto, CA USA
« Reply #7 on: May 16, 2024, 10:47:13 AM »
Elegant as always, Dave. And I love a split clamp -- the king of clamps. I'm curious as to what the friction surfaces in the clutch are, if it's not a trade secret 😊 Al on Al, or something else?
--Frank
Dave Garoutte
  • San Rafael, CA
« Reply #8 on: May 16, 2024, 12:22:53 PM »
--Frank
I'd have to take it apart, as it's been sitting in storage for a few years.  I think it's delrin, not a friction material.
Page created in 0.036 seconds with 23 queries.
