Author Topic: Midas Question  (Read 522 times)
Al Rettich
Midas Question
« on: March 15, 2024, 04:15:26 PM »
Knock on wood, I've had decent luck with Midas consoles. This one came back from a tour, and when I powered up, all sorts of red. The surface has a bad PSU, which is coming. I have no clue as to why MC/GUI 2 is red, or how to fix it. All the DSP cards are red, the stage has a PSU on a UPS which wasn't turned on.
Anyone have a number to Midas Tech Support in LAS? I'm tired, need sleep and on this one just want to follow instructions to fix it. I double checked connections from the DL431 to the DL371, X before Y. Checked all the cables making sure they were still shielded CAT 5.
Re: Midas Question
« Reply #1 on: March 16, 2024, 12:51:32 AM »
Trouble shooting the Tea Bag mixers isn't my strong suit, but...
Just a quick look makes me wonder if some other device with an RJ45 connector was patched to one or more ports on the DL racks or the DSP engine.  If a cable swap didn't fix your problem there is likely electrical/electronic damage.
That you also have failed PSU modules in the surface makes me wonder what happened, as the Pro series has had pretty reliable PSUs.
Re: Midas Question
Page created in 0.023 seconds with 23 queries.
