Author Topic: Shure SCM-810 auto-mixer channel LED's  (Read 1013 times)
Scott Hofmann
« on: March 08, 2024, 04:05:05 PM »
I am trying to set up this mixer in the "manual" mixer mode (no auto-mix). When I set DIP switch #1 down (to manual mode), all of the channel activity LED's stay green. Aren't they supposed to just light up just when there is input to each channel or are they simply telling me that each channel is active (on)?
Scott Hofmann
Milt Hathaway
    • http://www.fitzcosound.com
Re: Shure SCM-810 auto-mixer channel LED's
« Reply #1 on: March 08, 2024, 05:33:34 PM »
They just tell you if the automixer has the channel "on". Manual mode just tells the automixer to open them all up.
Milt
FitzCo Sound, Inc.
Midland, TX
Mike Caldwell
  • Covington, Ohio
« Reply #2 on: March 08, 2024, 11:16:01 PM »
For as expensive as those are I never felt the auto mix function worked that well.
Considering for about the same cost or a little less you can get a UI24, QU SB, QU Pac or a CQ 20 with more features and a far better auto mix function.
« Last Edit: March 08, 2024, 11:19:48 PM by Mike Caldwell »
Kevin Maxwell
  • USA SW CT 46miles from MidTown Manhattan ATCF
« Reply #3 on: March 09, 2024, 08:55:49 AM »
I have used the SCM810 automixers a lot and have had very good results when using them. I was going to copy and paste some of what I have written about that but it was more information than I felt was necessary to make my point. And that is not what the OP was asking. If you are using the SCM810 for the automixing I have found it works best if you engage the Last Mic Lock on feature. It is much smother that way. I mostly used them with a console using the post fader direct outputs of the console to feed the SCM810.
WAY MORE information available on request. BTW I really like the Dugan Method (gain sharing) of Automixing But there have been times that I liked the comparator circuit in the SCM810 and missed it when using the gain sharing method. I also encountered a mixer with built-in automixing that didn’t work as it should and I even spoke to Dan Dugan about it. And he agreed that the behavior I described to him was not how it should have been working.
Scott Hofmann
« Reply #4 on: March 09, 2024, 09:26:24 PM »
Thank you everyone for the information. I see where the "lock last mic on" really smooths out the auto-mixing.
It was an eBay purchase so did not spend the big bucks for a new one.
Scott Hofmann
Jordan Wolf
« Reply #5 on: March 20, 2024, 09:34:08 PM »
I have used the SCM810 automixers a lot and have had very good results when using them…
Me, too.
I prefer them in a reinforcement situation over a gain-sharing type AM as the audible phasing of closely-positioned mics is very reduced or eliminated. On record/broadcast/stream, gain-sharing works nicely.
I wonder how the SCM820 works in comparison…maybe I’ll rent one to try out on a corpy gig.
(Years ago, I needed a console that could handle over 48ch. of XLRs and the local rental houses only had a Yamaha PM3k…a stack of six linked SCM810s, along with some creative patching & routing, and I had a stable & intelligible setup.)
--Airport Circle Sound Reinforcement, LLC--
Page created in 0.02 seconds with 23 queries.
