Pages: [1] 2 3 4   Go Down
Author Topic: Connected ground required for all lighting fixtures?  (Read 5100 times)
David Allred
« on: January 10, 2024, 09:19:00 AM »
The fixtures are ADJ Mega Hex Par x4 on a T-bar.  These have a plastic housing and use IEC power inlets.  The supplied power cables are bulky and stiff.  I what to clean up the current routing scheme and use SJ cable for the tie-in drops along the bar to allow more flexibility.  For increased flexibility and reduction in build time I would like to use 2 conductor SJ.  Is there an actual reason to need the ground for these fixtures?
Electrical Danger?
DMX malfunction?
Thanks,
David
Re: Connected ground required for all lighting fixtures?
« Reply #1 on: January 10, 2024, 09:46:28 AM »
Electrical Danger?
DMX malfunction?
Thanks,
David
If equipped with an equipment grounding connection, then use a grounded 3 conductor cable.  I'm not sure any of us are willing to speculate in an open forum.
Daniel Levi
« Reply #2 on: January 10, 2024, 10:19:23 AM »
If it has a 3 prong inlet connetor then you use 3 core cable to a proper 3 prong/earthed connectors, no iffs or buts, though if you could guarntee the lack of a earth (it could be a technical earth for RFI supression) and change the connetors to a two prong version you could then use two conductor cable, but it would not really be worth it.
Brian Jojade
« Reply #3 on: January 10, 2024, 12:02:58 PM »
Will it work with 2 conductor cable? Yes.  Is it a good idea to ignore ground? Nope.
Ground conductors are there for unexpected failures.  While the risk is small, failures can result in DEATH.  Is it worth saving a couple mm of cable for that risk??
Brian Jojade
Stephen Swaffer
« Reply #4 on: January 10, 2024, 12:31:36 PM »
At my day job, one of the first questions asked when discussing a safety question is "What does the manufacturer say?"  In this case, "they" said it needed a ground and put a 3 wire cord on it-so that has to be the answer, for liability reasons if nothing else.
Steve Swaffer
Dave Garoutte
  • San Rafael, CA
« Reply #5 on: January 10, 2024, 01:06:11 PM »
you can probably use a fairly light gage, as the current draw is pretty low.
David Allred
« Reply #6 on: January 10, 2024, 01:56:30 PM »
Probably going that route.  22 awg rates for 3 amps, only requires  1/4 amp max per drop.  Even if I need to piggyback thru a fixture in a pinch, I'll have plenty of power available.
« Reply #7 on: January 10, 2024, 07:34:21 PM »
Are you asking about ignoring the "equipment safety ground"?
What could possibly go wrong?
Steve-White
  • Fort Worth
« Reply #8 on: January 11, 2024, 12:56:55 AM »
+1 on this one - do not omit ground wire.  Never ever.
Chris Hindle
« Reply #9 on: January 11, 2024, 08:51:38 AM »
You can be sure that if the manufacturer didn't NEED to use 3 wire, they would have used 2.
To me, it's as simple as that. Liability, safety, and insurance issues down the road are a scary thing to deal with if you don't have to.
Chris.
Pages: [1] 2 3 4   Go Up
Page created in 0.038 seconds with 23 queries.
