Just as a heads up, I have one of these in my hands right now and there is an issue with getting it set up.
Yesterday I hooked up a screen to it, hit power and it came on no problem. I then plugged a mouse into it and nothing. No input. No response. The mouse did "light up" so it had power, but there was no cursor on screen or any control. I then went and found an actual touchscreen (from an old POS) and tried that. Same thing. No cursor. I then tried a second touchscreen and still had no response. Getting pretty frustrated at this point so I went home.
Today I'm trying again and I found the cheapest, crappiest, low budget, Dell mouse and it works just fine. I can now get access to the Wifi settings so I can join the unit's built in Wifi AP.
If you are planning on using one of these make sure you have a variety of peripherals around to test on it to see what works and what doesn't. I'm really disappointed that the touchscreen doesn't seem to work since that would be the obvious way to control this thing. As it is now you HAVE to plug in a monitor and at least a mouse in order to join the built in Wifi so that you can pair a remote control unit (Ipad, PC, Phone) in order to start programming it wirelessly.
Also in looking through the "Wired" network settings there is no option for DHCP. It only has the ability to input an IP and Subnet mask and that's it. So even connecting this to a separate network wouldn't work since you still couldn't access the page that has the hidden password, even IF you discovered the device's IP address!
