Author Topic: Stacking Nexo Alpha EM  (Read 1482 times)
Juha Stark
« on: October 04, 2023, 06:27:10 PM »
Hi there!
Iíve got 4xEMs and the plan was to stack 2 of them on top of each other per side. I have seen that this is fairly common way to stack them. But there is some kind of interference happening since it doesnít sound as well balanced as when I only use one of the EMs.
Does anyone know if the sound could be improved with some kind of spacer between the tops? I guess I could EQ it but I prefer not to. These cabs sound nice just the way they are when driven active. 😊
Art Welter
  • Santa Fe, New Mexico
Re: Stacking Nexo Alpha EM
« Reply #1 on: October 04, 2023, 08:06:53 PM »
The larger the spacing distance between the cabinets, the worse the off axis interference pattern (comb filtering) will be.
Spacing the front of the cabinets to describe a portion of a vertical arc will reduce the high frequency pattern overlap, appropriate if more than 30 degrees of vertical coverage is required.
Examples attached.
¬ę Reply #1 on: October 04, 2023, 08:06:53 PM ¬Ľ
Page created in 0.031 seconds with 23 queries.
