Pages: 1 2 [3]   Go Down
Author Topic: on-off-on "light switch"  (Read 5194 times)
Bob Faulkner
  • Raleigh, NC
Re: on-off-on "light switch"
« Reply #20 on: February 26, 2023, 08:06:30 PM »
That's the switch style he outta be using.
It is a nice switch.
So, I procured a DPDT toggle and will work on getting it wired using the DPDT image (thank you Steve).  I do have a SPDT switch, which I may try as a backup.
Thanks
Steve-White
  • Fort Worth
« Reply #21 on: February 26, 2023, 10:27:44 PM »
Bob, a well lighted work area for loading is a very good idea sir.  You are most welcome.
Stephen Swaffer
« Reply #22 on: February 27, 2023, 01:19:35 PM »
Only a couple switches (both momentary only) on that cut sheet are rated for DC voltages-and the only for 3 amps.  There is a difference in design and while they will likely work for DC even if not rated, their lifespan will likely be shorter.
As an aside, a standard "3 way" light switch is SPDT and so could easily switch between two sources-but without the center off.
Steve Swaffer
Chris Hindle
« Reply #23 on: February 27, 2023, 03:47:36 PM »
How about a rotary switch? 2 pole. 3 or more positions. Switch only the positive. Use 3 pole and switch the negative too.
Center position off. right for "shore" power, Left for on-board power. Tie the lights positive to both left and right terminals. Do the same to Pole 3 for Negative if you feel the urge.
Chris.
Patrick Tracy
    • Boulder Sound Guy
« Reply #24 on: February 28, 2023, 08:25:53 AM »
If you're going to use a double terminal switch, look for "break before make" instead of "make before break." That will do essentially the same thing as an on-off-on, but without stopping at the off position.
Bob Faulkner
  • Raleigh, NC
« Reply #25 on: February 28, 2023, 09:40:54 PM »
I considered a 3-way, but needed the off capability.  As well, I just placed an inline fuse (2-amp) in the setup.  The lights (small LED strips) probably only consume about 1-amp of current.
Pages: 1 2 [3]   Go Up
Page created in 0.041 seconds with 23 queries.
