Author Topic: Speaker selection  (Read 1676 times)
Andy Pearson
Speaker selection
« on: February 20, 2023, 08:45:24 PM »
We have a 50ft wide x 70ft deep church sanctuary. Which one of the two pa cabinets listed below would be better and why?
JBL AM5212/00 12-inch 2-way Loudspeaker or the JBL SRX812 12 inch Passive Speaker?
Mike Caldwell
  • Covington, Ohio
Re: Speaker selection
« Reply #1 on: February 21, 2023, 01:43:18 PM »
Going to need need a little more info.
How high is the ceiling in the room.
What kind of program content will the system be used with.
How is the room finished out.
Andy Pearson
« Reply #2 on: February 21, 2023, 10:36:21 PM »
10ft side walls up to 15ft in center ceiling height.
We are a church with a full band and 5 vocals and very dynamic pastor.
Room has sheetrock walls, carpet floors, and acoustic drop ceiling tiles.
quote author=Mike Caldwell link=topic=178505.msg1648150#msg1648150 date=1677004998]
[/quote]
Matthias McCready
« Reply #3 on: February 22, 2023, 10:11:42 AM »
What kind of SPL are we talking?
And do you have subwoofers?
Measure twice, and cut once; this is especially important if you are a mohel.
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: February 22, 2023, 10:17:03 AM »
You should be looking at something like two center hung arrays of two speakers each.
One for the mains and another 2/3rds ish way back for delay fills.
Covering that depth with that ceiling height will be a challenge.
The JBL 5212/00 has too wide of dispersion, the SRX812 would be slightly better. Look at something with a larger format HF driver and around a 60 X 60 horn pattern.
« Last Edit: February 24, 2023, 09:32:49 PM by Mike Caldwell »
lindsay Dean
« Reply #5 on: February 22, 2023, 12:58:00 PM »
I have installed these in projects before they punch above their weight the processor needs to be purchased with the speakers but they are fantastic http://www.yorkville.com/installation/coliseum/product/fh1w/
Sixty degree conical horn with mid range and high  drivers mounted in the same horn mechanically aligned If you want research unity horn
« Last Edit: February 22, 2023, 01:17:00 PM by lindsay Dean »
     and Pray for higher guidance
Andy Pearson
« Reply #6 on: February 23, 2023, 09:27:51 PM »
Spl levels between 80 and 90.
Yes we do have 15" subs
Mike Caldwell
  • Covington, Ohio
« Reply #7 on: February 24, 2023, 06:57:13 PM »
That seem really low on the SPL on any scale.
What have you measured it with and from where at.
Andy Pearson
« Reply #8 on: February 24, 2023, 09:14:43 PM »
Those are very standard levels for evangelical worship services.
Page created in 0.031 seconds with 25 queries.
